Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
How to fix error 322 on linksys wag120n
Error 322 while installing new cisco linksys wag120 n
Getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Posted on Nov 02, 2014
3 Suggested Answers
  • 10406 Answers
SOURCE: I have tried connecting Cisco linksys router but
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Posted on Feb 21, 2011
TechyDrood
  • 2072 Answers
SOURCE: solution for error 322
From the computer you are trying to configure the router from. Make sure you have an ethernet cable plugged in from the computer to one of the four numbered ports. You do not want one plugged into the wan/uplink port, this port is to be connected to your cable or dsl modem. Also open a command prompt, press the windows key and type "cmd" <enter> then type "ipconfig" <enter> scroll up and look for an IPv4 address it should start 192.168.x.x. If it starts with 169.x.x.x then your computer did not aquire an IP address via DHCP. If it shows as 169.x.x.x type "ipconfig /renew" <enter>. If it tells you, you don't have permission click windows key > All Programs > Accessories, right click on "Command Prompt" and click "Run as Administrator and repeat the last step.
Comment back if you need more assistance.
Posted on Nov 21, 2011
Network Magic 5.5 Key/Serial/Activation
i need network license key cisco wag120n
Feb 04, 2013 | Cisco NM300 Network Magic Pro 5.5
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
Solution for error 322
Nov 20, 2011 | Cisco Linksys WRT54GS2 Wireless-G...
Configuring linksys wag120
Here's the manual:
http://downloads.linksysbycisco.com/downloads/userguide/1224645029534/WAG120N-160Nv2-320N-EMEA_UG_C-WEB.pdf
Page 7 is probably what you're looking for
Mar 15, 2011 | Computers & Internet
I have tried connecting Cisco linksys router but it gives ERROR 322 NEW ROUTER OR GATEWAY NOT DETECTED...How can I solve this problem please advice
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Press Enter
Feb 21, 2011 | Cisco Linksys Wireless N Home Router...
I receive the 322 error when I´m trying to install my new WRT160N v3 Router, by Cisco.
I think you are trying to install the router using the CD. This CD has a bug. Even if your computer is connected to the router , it will say the computer is not connected to the router and it will give you error 322 or 321.
You can install the router without CD also.
Make sure that your computer is able to go online through the modem only.
connect the computer and the modem to the router and open the set up page of the router.
On the set up page you can change the settings of the router according to ISP.
Click Here for step by step instructions
Feb 01, 2010 | Linksys WRT160N Wireless Router
Error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
May 12, 2009 | Linksys Wireless-G Broadband Router
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
199 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
