Question about Electrical Supplies
Diagram for motion sensor with dimmer switch
Clipsal sensor with rotary dimmer switch
3 Suggested Answers
SOURCE: My rotary dimmer doesn't switch 3-ways. I have to
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Posted on Dec 01, 2010
SOURCE: I installed a single pole rotary dimmer in my
Rotary dimmers are not normally suitable for fan control plus not all types of lamps are dimmable , so used wrongly a dimmer could catch fire.
Steve
Posted on Nov 07, 2011
What wires goes on Load and Line. on a clipsal rotary light dimmer
In normal house wiring, 110 vac, the black lead is considered the "hot" or line lead and the white one as the neutral. When wiring to a variable resistor, the variable lead normally goes to the load so the voltage can be changed and the other lead to the "line."
Feb 13, 2015 | Rotary Electrical Supplies
I need a wiring diagram to wire two way dimmer switched in place of normal switches
Take off the 2 wires from the old switch... put on the 2 wires from the dimmer. the 3rd wire is a ground it is green put it on a ground screw at the back. If your switch has more wires it is likely a 3 way system and needs a 3 way switch instead.
Apr 04, 2013 | Cooper Wiring Devices 6009W-K ROTARY...
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
I have motion lightts on my back porch. I would like to just plain turn them on when I have a back yard party, but I don't know how to over ride the motion sensor. Can you help? Thanks.
On most motion sensor lights if you turn the switch on, then off and on quickly, they will stay on till you turn them back off. Leave it off for at least 10 seconds and turn it back on to go back to the motion sensor.
Sep 06, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I have two wall switches in a hall for an over head light. I would like to install a rotary dimmer in one of the switches. My dimmer has 1 green and two black wires, and my wall switch has 2 black, 2 red...
You cannot, at least not using the dimmer you have in your hand. The switch with all the wires is a four-way switch, which is used to make a "suicided" 3-way switch. The power comes in AND goes out to the light from that switch. The other switch is a 3-way. Neither one has the "ON" or "OFF" marks on them, do they? You can buy a 3-way dimmer, but i do not know if rotary-style 3-way switches exist. You will have to install the dimmer at the other switch because i am quite certain no 4-way dimmers are available.
Nov 20, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
How do you connect a motion sensor light switch to a chord that can be plugged into a wall?
hmmm lets see... what is the motion sensor controlling?... lets assume it is a lamp with a plug on it. so you need to wire the motion sensor so that it has a male plug on one end and a female plug on the other. lets also assume it is two wire lamp cord and a two prong plug. Take a standard extension cord and split off one of the wires and cut it, attach one of the motion sensor wire to one of those wires and the other motion sensor wires to the other wire.. so the motion sensor is splitting on of the wires.. oh this would be so easy to draw...
Nov 05, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Jan 31, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Electrical Supplies Logo
56 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
