Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does not spin all the way & Mildew smell
We have a problem with one we that was in the home we just purchased, go figure we had a great older set at our old place and got rid of them before we made sure our new and bigger ones worked all the way... The problem we seem to be having is that it will spin but not all the way, like it leaves the clothes soaked like it does not have enough time to finish the cycle out so we have to wring them out and it takes FOREVER...Also when we first opened it up it had a really bad mildew smell and it had black gunk all along the top of the drum on the inside, we cleaned it with an SOS pad and got it off but it still has a slight mildew smell, is there anything I can do to make it go away? Thank you.
  • 87 Answers
You can poor bleach in it and let sit for a while. For your spin problem you may have a slipping clutch and dragging brake shoes. Will need to take apart to fix.
Posted on Jun 08, 2007
SOURCE:
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
The washer has a terrible mildew smell. What can you do to eliminate this?
Take a rag and wipe out the inside of the door gasket. Also the best product to clean would be AFFRESH. You can purchase it at your local parts distributor or probably like lowes or home depot. Also leave your door cracked open between uses this will eliminate the mildew from building up.
Let me know if this helps
Jan 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lg washer smells stinks
you have a blockage in your drain line. you could snake it, pour drain cleaner in or do both. once your unblock it the smell will clear up.
Sep 16, 2009 | Washing Machines
LG washing machine has AWFUL mildew smell
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
Odor coming from front door jams after shutting car door
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Apr 11, 2009 | 2002 Dodge Durango
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
Oct 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Two problems, mildew smell and loud noise in spin cycle
drum bearing failure due to the water seal in front of the bearings failing the smell is probably the grease mixed with water in the outer tub
Jul 15, 2008 | Frigidaire GLTF1240A Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
97 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
