Question about RCA Televison & Video
Turning off the parental controls on RCA projection T V's
Solution to turning off parental controls on RCA projection T.V.'s: If you forget your password, press the MENU button, then select Parental Control (the password entry screen appears). Simultaneously press and hold CH+ and VOL+ on the television for 3 seconds. Parental Controls unlock and the Parental Control menu appears so you can enter a new password.
    Top Expert:
  • RCA Master
  • 14,553 Answers
It seems you have answered your own question, I have noted and archived it--for future use to help others.
Posted on Dec 04, 2012
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
  • 80 Answers
SOURCE: parental controls
If you forget your password, press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls
Posted on Jul 23, 2008
VOTIT
  • 2071 Answers
SOURCE: Hi , Got a philips
SERVICE MENU SETTINGS
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen.
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
panel
Displays panel resolution
power on time
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values
Posted on Jul 30, 2008
  • 899 Answers
the reset procedure is in your user manual
Posted on Oct 30, 2008
pabloloco
  • 2335 Answers
SOURCE: Resetting the parental controls
I can help you unlock your Mitsubishi HDTV VChip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Posted on Apr 30, 2010
Trying to remove parental lock on Apex Digital AT 2702s 27'' tv with a RCA universal remote
The parental lock is part of the initial setup procedure selected by the Apex remote.
Mar 05, 2013 | Apex Digital AT2702 27" TV
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
How do i reset my RCA projection tv
Hello
If you forget your password, follow step one above to get to the
password entry screen. Then press the VOL+ and CH+ buttons on the HD
Monitor's front panel at the same time for at least 8 seconds. You will
receive an on-screen message that Parental Controls have been unlocked
once you've successfully reset the password
Nov 20, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to deactivate parental control
Hi Ida,
If you don't have the password to deactivate partental control you can do the following:
Power on TV, Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ buttons on the front panel of the TV for 8 seconds.
An on screen box should appear, select a new password if desired or leave blank for no parental control lock.
Hope this helps, Gary
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 rca hdtv is lock ann i forgette the code#
Owner's manual, page 31. Menu Parental Control Chan+ & Vol+ for 8 secs. It unlocks, and you can enter a new password if wanted.
Jun 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Some of my channels are blocked and i forgot the password, so how can i unlock it it's an rca
Owner's manual, page 31. Menu-Parental Control-Chan+ & Vol+ for 8 secs. It unlocks, and you can enter a new password if wanted.
May 27, 2010 | RCA HD52W59 HDTV Projection Television
How to reset password for Parental control or timer? TV shuts off after viewing for about 40 min to an hour.
RCA R52WH73 Television
Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ on the front panel for 8 seconds.
Select new password if desired.
Good luck,
Techjoel
May 11, 2009 | RCA R52WH73 Projection Television
Parental control
Oct 30, 2008 | RCA P46924 46" Rear Projection Television
Parental controls
Parental Controls
Aug 26, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
