Question about SVP TPC7901 7" 2 GB Slate Tablet - Wi-Fi - Infotmic iMAPx200 1 GHz - 800 x 480 WVGA Display - 256 MB RAM - Android 2.1 Eclair - HDMI
Svp failure to go past logo at startup
After startup unit will not go past the infotmic logo
Hi i have a coolpad avail 3300 and when i turn it on it doesn't go past the coolpad logo it stays stuck on that screen what do I do
Coolpad Arise locked on startup screen : perktv - Reddit
https://www.reddit.com/.../coolpad_arise_locked_on_startup_scree...
RedditApr 21, 2015 - The community doesn't take too kindly to it either. ... charged battery, or on just the power cord, but it will not go past the "Coolpad Arise" logo.
Coolpad 3300A wont go past the start screen where it says ...
www.askmefast.com > Computers & Internet > Security > Screen
Coolpad 3300a wont go past the start screen where it says coolpad? ... Coolpad won t go past start up screen ... Software for avail coolpad 3300a phone ..... Can i get a new 4g coolpad for mertopcs if part of the screen doesn`t really ... coolpad phone model 3300a always freezing at the coolpad logo and how to unfreeze it?
Jan 01, 2016 | Computers & Internet
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
How to disable the Startup Logo (White BG with Name)?
It is built into the software and cannot be removed.
Oct 13, 2014 | Computers & Internet
How to install or conect a SVP TPC1015 10" tablet to a pc?
just have to plug in usb to PC.. will charge and look like thumb drive as well.
May 10, 2014 | SVP TPC7901 7" 2 GB Slate Tablet - Wi-Fi -...
How do I get my sylvania smartbook to get past the infotmic screen when starting up. It is stuck there and will not load any further, I'm not sure what's wrong with it.
either the bios is corrupt ,or the set up has been edited improperly, or the windows program has been corupted, 1st try rebooting the computer ,at the startup enter to the setup screen, check the settings, write them down, make shure to have the boot sequence set to 1st boot to A drv , 2nd CD rom 3rd external usb or internet, last must be the hard drive, that way then reset to factory settings, from that screen will popup ,do you wish to save settings, enter yes, then reboot, with oem install or backup rescue disk in the computer!
Jan 28, 2013 | Computers & Internet
Cannot get past the infotmic logo.How can I get past this?
hard reboot and use F8 key until unit starts in safe mode this will allow you the options to review some start up issues and also may need to hard reboot and use either F10 or F12 key depending on your PC/Laptop brand and be sure your are booting from the HardDrive.... if you have a "repair disk" that came with your unit you can put it in the CD/DVD drive and then do a hard reboot and do F10 to boot from CD-ROM this will allow you to run a repair disk on the unit to see if your missing any files or programs etc. Good Luck . Or use this website: http://www.geekstogo.com/
Jan 28, 2013 | Sylvania G-Netbook
Stuck in boot sequence, how can it be fixed
You haven't mentioned which version of android it has but you should be able to reset the tablet with the reset button on the back - hold it in for five seconds.
If that doesn't work then you could try the solution posted here
http://www.androidtablets.net/forum/sylvania-tablets/31958-svp-tpc7901-boot-loop-problem.html
I am in no way connected with the solution on the link and accept no responsibility if things go wrong.
You could always return it if it's under guarantee.
Jan 18, 2013 | SVP TPC7901 7" 2 GB Slate Tablet - Wi-Fi -...
S7000 freezes on startup
may be CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
Mar 05, 2009 | Fuji FinePix S7000 Digital Camera
SVP TPC7901 7" 2 GB Slate Tablet - Wi-Fi - Infotmic iMAPx200 1 GHz - 800 x 480 WVGA Display - 256 MB RAM - Android 2.1 Eclair - HDMI Logo
Top SVP Computers & Internet Experts
David Payne
David Payne
Are you a SVP Computer and Internet Expert? Answer questions, earn points and help others
