Question about Casio Parts Cash Register PC Desktop
Error Code E014 Casio PCR-T470
Receiving this error code E014 Receipt Paper and do not have any paper to load. I was trying to program PLU #'s and accidently hit some key that used all my paper for some huge report. Need to know how to clear to continue programming.
  • donnguyen205 Jan 26, 2009
    E260 EJ FULL. How to fix this problem if you know?
  • 737 Answers
Hi. When they run out of paper, you just load a new roll, and the machine will automatically continue. There is no need to clear the error. It will continue when it senses fresh paper in the receipt side.
Posted on Jan 12, 2009
2 Suggested Answers
flexion1
  • 737 Answers
SOURCE: I am receiving Error Code
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
Getting error e004 on te-2200
Try this:
Turn key to PGM (program) mode
Turn power off at the wall socket
Hold down RECEIPT FEED button (keep your finger on it)
Turn power back on and wait 5 seconds before taking your finger off of the receipt feed button (the paper may feed out. This is normal).
The LLLLLLLLLL part of the display should change to FFFFFFFFFF.
Press SUBTOTAL once and wait for the printer to issue a receipt.
Turn key back to REG mode and try it. You may need to sign on using a clerk button or a clerk code if you use one.
Sep 22, 2015 | Retail Supplies
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
Adding new PLU problem keep getting PLU Program Error
Those machines have a memory allocation section where you need to define the file sizes for products, etc. If your file size is smaller than the machine you are copying from, then it wont work. Try setting the memory allocation first.
Apr 04, 2014 | Samsung SAM4s ER-650 Cash Register
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Aug 04, 2013 | Casio tk-3200 cash register
With my Casio TK-1550, I'm getting an E014 saying it's out of receipt paper. Even though I've inputted the receipt paper correctly the error still appears and I cannot relinquish any cash from...
I have had this before when the paper was the wrong size. make sure the paper is the same width as the printer and it is covering the little sensor on the printer. Make sure you have closed the platten arm down onto the paper fully. If this doesn't correct the problem, you may have to see a dealer. ---------------------------------------------------------------------------
If anyone needs more information, the Casio TK-1550 operating and programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1550_user_programming_manual.html
May 12, 2011 | Casio Parts Cash Register PC Desktop
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
Paper Drawer is out of order
DRAWER OUT OF ORDER
You have to reset the drawer by;10871087 and run SIM 906
You should be able to just key inthe Code you wish, then hit the print key to activate.
Thenuse the touch screen to reset then print key again.
Jan 26, 2009 | Kyocera Copystar CS-5035 Copier
I am receiving Error Code E014 Receipt Paper for Casio PCR-T470 and do not have any paper to load. I was trying to program PLU #'s and accidently hit some key that printed a huge report and used up all my...
Jan 11, 2009 | Casio Parts Cash Register PC Desktop
Casio tk-7000 scanning and PLU programming
I think I see what you are trying to do here
plu codes http://en.wikipedia.org/wiki/Price_Look-Up
these plu codes are for networked tills where prices are controlled by the till server (a central list of prices used by all tills)
whereas I think you are trying to assign prioces to individual keys, and therefore you should use this guide. to program the prices to the keys
http://www.calcullus.co.nz/Manuals/Casio%20TK-xxxx.pdf
I hope this helps
Oct 04, 2008 | Computers & Internet
Casio Parts Cash Register PC Desktop Logo
868 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
