Question about Admiral ATW4475XQ
Admiral ATW4475VQD water won't fill
Water will not fill at any settings
    Top Expert:
  • Admiral Master
  • 9,472 Answers
Does the lid switch work? With the lid closed, put the unit to spin cycle. If it spins, the switch is good and you will need to replace the water inlet valve.
Here is the switch if you need it.
Here is the water valve if you should need it.
Posted on Dec 04, 2012
  • 3 more comments
  • Munetaka Araki Dec 05, 2012
    Water problem is half fixed. Now the hot water will not come out? please help
  • Richard Roth
    Richard Roth Dec 05, 2012
    Do you have the hoses hooked to the right inlet valve?
  • Munetaka Araki Dec 06, 2012
    yes. hot water hose to red and cold water to blue, correct?
  • Richard Roth
    Richard Roth Dec 06, 2012
    Yes, that is correct. You replaced the inlet valve?
  • Munetaka Araki Dec 13, 2012
    I ordered the new water inlet vlave and got it today. I am going to switch it tonight
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
WATER WON'T CUT OFF
Possible that the water level sensor has failed and so does not trip the controller to shut off the inlet valve. The sensor is a pressure activated switch and you must be able to track it down and test the switch to work with air pressure. If so the switch must be replaced.
Jun 05, 2012 | Admiral AW22 Top Load Washer
Admiral atw 4475 vqo washing machine won't fill
Try holding the start button in for 5 seconds, this will reset the circuit board. It worked for me.
Jan 05, 2012 | Admiral AW22 Top Load Washer
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Have a top loader Admiral which has a shut off problem: cold water will not shut off even when unplugged...figure it's the cold water selonoid.
Yes exactly the problem w/power off and it continues to fill it's defiently the solonoid valve
Gene
Aug 04, 2011 | Admiral Washing Machines
When the washer is ready to wash,the water keeps coming in to the washer,won't shut off
Open the control panel. Remove the plastic hose from the water level switch.
Blow through the hose to remove any blockage from the air bell at the tub. Reattach the hose and set the machine for a SPIN cycle and run the machine. Then re-fill with water.
Double check the hose for any kinks or pin holes.
If this does not correct the problem,the water level switch will need replacing.
Aug 04, 2011 | Admiral AW22 Top Load Washer
Washer won't fill. will only agitate or spin
Set the washer to the position where it should be filling up with water. With the solenoid leads unplugged check if its getting 120 volts to it using a voltmeter or a circuit tester. The solenoid I am mentioning about is the one that opens up to let the water into the tub. When 120 volts is applied to it the solenoid opens up the water valve. It is located on the back of the machine. Then we go from there.
May 28, 2011 | Admiral Washing Machines
Admiral ATW4475XQ Logo
204 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
