Question about Sharp Zaurus ZR-5000 PDA Personal Electronic Organizer
I have a sharp zarus SMB 5800- The problem i have experienced is that i cannot open my documents file
When open the memory it shows that documents are inside however when I try to tap/click the icon to open the file nothing happens? could I start a : RESET, HARD RESET? please give instructions a)I have also used the search feature to locate files with common names normally used however, it will not search ..comes up blank. b)before this problem occured I had an issue with taking some batteries out manually in which i tapped onto the battery area to hlep shake them out. thank you jim
2 Suggested Answers
SOURCE: Sharp ZQ4450 electronic organiser not working
Try the reset.Hold the ON button, press the RESET switch on the back. Release the RESET switch and then press ON.
The display will ask CLEAR ALL DATA.
Do not press Y
Posted on Nov 08, 2012
ZR-5800 won't restart
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 10, 2012 | Sharp Zaurus ZR-5800
My nokia 5800 memory card is locked after restarting the mobile.now how i can open my memory card.
Hell Jannaan,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
May 18, 2011 | Nokia 5800 XpressMusic Smartphone
The themes that ive download are not able to open.
Here are several problem that can be causes :
- Disturbed while downloading the themes, so the file corupted.
- Themes resolution is not match with 5800
- Themes file is too big so its hard ford the phone to open it, usually themes with many animations.
- Little memory space in your phone memory
Hope this help.
Feb 22, 2011 | Nokia 5800 XpressMusic Smartphone
My mobile nokia 5800 expresmusic memori card 8GB is loked pleas give me passward number
To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
http://fexplorer.en.softonic.com/symbian/download
After finished downloading, install it to your mobile phone.
Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
Run FExplorer and open the following location C:\system.
From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
When you finished the above steps, you will find the password of that file.
Aug 07, 2010 | Nokia 5800 XpressMusic Smartphone
My mobile nokia 5800 xpress music i forgot my password can u help me how to open micro sd 8gp card
Install fexplorer in phone memory. Then look in c drive of phone, you will find a file called mmcstore. Copy this file to yor computer and open it with notepad. At the end of this file yo will find your memory card password.
Thanks for using FixYa. Please rate the answer.
Aug 01, 2010 | Nokia 5800 XpressMusic Smartphone
Cannot play the music
ok
just reset your phone
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up
May 10, 2010 | Nokia 5800 XpressMusic Smartphone
Forget password of memory card problem
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • Now you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Nov 19, 2009 | Nokia 5800 XpressMusic Smartphone
Music in music library shows corrupted cannot delete
Connect ur phone to ur PC in Data transfer mode.
Make sure u can view hidden files in ur pc.
Open E:\private\
where E: is ur memory card drive name
Delete all the files in "private" folder.(u can copy and save all the files before deleting incase anything goes
Disconnect ur phone and restart it.
Open music library it will refresh itself automatically.
Mines working fine now....
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
I lost my communication ZR-AP2C software for Sharp Zarus ZR3500X
Have you tried Hyperterminal. It is included with WinXP. Look in the communications menu in accessories.
You may also try Sharp's website to see if there are any downloads for the ZR-AP2C
Sep 23, 2009 | Sharp Zaurus ZR-3500X
Nokia 5800 memory card unlock code
well if your phone does not have a file manager place the mem card in one that has one then use the file explorer go to drive c or whatever drive represents the card find a file called mmcstore rename it to a .txt file open it on the phone or if it cant send it to a pc the password would be in it
Aug 23, 2009 | Cell Phones
Sharp Zaurus ZR-5000 PDA Personal Electronic Organizer Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
