Question about 2003 Ford F-150 - XLT, 6 6" short bed, standard box - ProCap Bed Caps
Low beam doesnt work but high beam does
Changed light bulb but same result
  • 10,263 Answers
The head light switch isn't working
Posted on Jan 23, 2014
Head light have low but when using high does not work just on one side drivers side
HELP! headlight not working even after change - Nissan Forums ...
www.nissanclub.com/...nissan.../302674-help-headlight-not-working-eve...
Apr 1, 2010 - 13 posts - ‎6 authors
My passenger side low beam headlight recently went off on me. ... I've changed the bulb again, and changed the fuse just in case, but .... My driver side headlight wire got loose so when i hit a bump at night if would flicker. ... When you notice one side not working (Low or High beam) it could be the module. Headlight replacement
Jan 22, 2009
Low beams don't work but High's do
Mar 20, 2005
More results from www.nissanclub.com
Dec 20, 2015 | 2004 Nissan Sentra
High beams work for both lights, 1 low beam does not
Check for power with a test light with the light connected. If you have power then its the ground. If no power then you will need to trace the wire back to find break. As I recall they did have seperate fuse for left and right headlight high & low beam. Also did you get a defective new bulb?
May 31, 2015 | 2006 Mazda Tribute
Prius high beam lights work but low beam lights do not work?
On a 2008 Prius, If both High beams work but only one side has working low beams, then it is most likely a fuse. So before breaking your knuckles to change the bulb, check the fuse first. I found out the hard way as my mom distressed to me that her drivers side headlights were out. So without checking to see if low and high were working, I proceeded to remove and replace the bulb - ouch! There are 4 10 amp fuses that protect the circuits for low/high beam function. They are under the hood in the fuse box on the drivers side and they are marked on the box cover. Check them before changing the bulb.
Oct 29, 2012 | 2006 Toyota Prius
2008 gmc truck Low beams quit working. I have High beams and running lights only. whats possible fix?
Are the bulbs good?
If your low and high beams are on the same bulb, then the low beam elements have blown even though the high beam still works, you need two new bulbs.
Apr 04, 2011 | 2008 GMC Sierra 1500 2WD
My high beam light(s) on 1994 Honda gold wing GL 1500
They are the same. It is one bulb with two separate elements high and low. You have to replace the bulb. kind of hard to explain how to do it though.
Nov 02, 2009 | Honda GL 1500 Gold Wing Motorcycles
High beam indicator light
MY HIGH BEAM LIGHT IN DASH DOES NOT WORK JEEP tJ
Apr 12, 2009 | 2003 Jeep Wrangler
2003 Ford F-150 - XLT, 6 6" short bed, standard box - ProCap Bed Caps Logo
55 people viewed this question
Top BAK Vehicle Parts & Accessories Experts
Lawrence Oravetz
Gloria Vernon
Gloria Vernon
Level 1 Expert
Are you a BAK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
