30 amp rv outlet wiring diagram
Want to wire an outlet in my storage shed for my camper
  • 6,674 Answers
Hot , Neutral & Ground, same as other household circuits, only heavier gauge wire to carry 30 amps, as well as 30 amp breaker in panel. Keep in mind, it is a 120VAC circuit, not 240VAC.
Posted on Feb 01, 2013
motor1258
  • 6674 Answers
SOURCE: I need the wireing diagram for a coleman rv/ac
If it is mechanical controls at ceiling, this link should be it. It's a service manual, but has what you need and more.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
If that's not yours, try ( http://www.rvcomfort.com/rvp/rvp.php ) and go to technical information and search for yours.
Posted on Jul 07, 2010
22yooper
  • 828 Answers
SOURCE: need wiring diagram for a
1-800-835-3278 Coleman consumer service.
Posted on Jul 03, 2008
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
  • 2920 Answers
SOURCE: ADDING 2ND AC UNIT TO RV
change out the breakers
Posted on Jan 04, 2009
  • 141 Answers
SOURCE: A/C in camper won't run. Keeps blowing the 14 amp
no you need to install a hard start kit on that unit to help it start up easer i can get one for you and help you install it by yourself jason
Posted on Apr 05, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
I plugged a 30 amp power supply cord from an rv to a 15 amp house outlet to run a/c to rv . gfci tripped and wont reset. damaged gfci or something else?
A GFI outlet works independently of sensing an overload condition. Overloads are dealt with by the circuit breaker or fuse in your electrical panel. The GFI simply compares the current on the hot terminal (black or red wire) with the current on the neutral terminal (white or gray wire) and interrupts the current if there is more than 5mA (0.005 Amps) difference between the two.
Remove the load - in this case the RV plug - from the GFI outlet and attempt a reset. Make sure you're pressing the RESET button and not the TEST button. If it resets - you're all set. Reconnect the RV plug to a different outlet - preferably NOT a GFI type.
If it still wont reset, it is important to know that GFI outlets can be wired in such a way that any circuit extended to other outlets (lights, too) via the LOAD terminal screws will also be protected by the GFI. We need to be sure that there wasn't something else causing the fault. Check other nearby outlets for functionality. Remove plugs from any outlet found not working and attempt to reset again.
If it will not reset - it is possible that the internal sensing circuitry has been damaged due to such a large amount of current trying to pass. In this case, replacing the GFI outlet will be needed.
Oct 09, 2015 | Washing Machines
I can use some help on a 87 Winnebago wireing in the living area someone thought that needed it more than we do any one have a diagram for such a thing
It is very difficult to find a manual for any certin type of rv or camper. Your best bet is to find a self help book that deals with rvs or campers in general. They should be able to tell you what you need.
Oct 08, 2014 | RVs
Need wiring diagram for dash on 1987 chevy
That won't do you any good, since the system you are describing is pit in by the conversion company and they are notoriously tight fisted with wiring diagrams. Back to a dealer you go for this problem. Sorry
Mar 14, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
Wiring diagram
0eaf58a4-fc80-49d8-8ec4-753d2bda9770.gifuse the flow chart . for fix it.
God bless you
Jul 11, 2013 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a 1999 F250 Super Duty Lariat Super Cab 7.3L diesel.The wiring for the tow hitch is 4 prong flat with 3 extra wires.What was included from the factory and\r\nwhat do I need to pul camper with rv...
With 4 prong and 3 extra, that will give you what you need for 7 prong for towing RV. If your not too experienced in that area, a mechanic at any trailer place, or hitch installation place or who knows RV wiring, should be able to do it for you in about 1/2 hr. or less. Testing the wires from your truck for what they do as in right , left, stop, running/taillights, etc is about the hardest part, and the 7 prong usually comes with what terminal does what.48e2ffb.jpg
Jun 10, 2010 | 2002 Ford F250 Super Duty SuperCab
Heating & Cooling Logo
388 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
