I have a lg 47 lm6700 3d television I turn it on it shows the opening screen then shuts off! Then immediately cuts right back on and then off at opening screen and just keeps repeating this until I unplug it!!!
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Either a problem in the power supply or with the main board that controls all functions---if you have to unplug it that points to a control issue of some kind.
Most likely a shop repair----find and replace the board causing this.
Google the model number with "parts"---there is a seller who sells all the boards listed by model number---you can see what boards it uses and the cost of each.
Posted on Dec 04, 2012
  • Tim Lawson Dec 06, 2012
    Thank you!!! How do I tell which board it is!!
5 Suggested Answers
  • 62 Answers
SOURCE: Powers on, screen flashes Akai screensaver and then shuts off
Take the unit into the service center - have the service center diagnosed the problem - they will order the part - but the parts are not available - DONT WAIT - The manufacturer must exchanged the unit because the the manufacturer must provide the parts for up to 5 years by law after the the tv is manufactured. Have the service center provide you with a workorder stating the television is not repairable because the parts are not available - then call 800-726-4405 - they will start hte process to exchange the televsion - LONG PROCESS to get an exchanged television
Posted on Mar 29, 2008
  • 5 Answers
SOURCE: LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Posted on Dec 13, 2009
  • 3 Answers
SOURCE: My 47' LG HD television
I had the same situation with my 47" LG. I opened the back and found 3 bad capacitors (bubbled on top). I replaced them at a cost of $1.20 ea at Radio Shack. I'm no expert at replacing these, so I let you tube be my teacher. I saved myself over $200 by doing it myself, not to mention there are some dishonest people out there that'll lead you to believe your TV is shot.. See the pics below of the "bubbled/bad" capacitors. These shoud have flat tops..Hope this helps....01b92fd.jpg
Posted on Oct 16, 2010
barbu51
  • 566 Answers
SOURCE: My Emerson LD195EMX is flashing
Hi Jamie, welcome to fixya
I have here a procedure that works well on Sylvania tv`s , since both brands/models are made by FUNAI , it may work on yours as well.
With the tv`s original remote control and in one sequence, press the arrow left then right and power.
As i said this works with sylvania but will it work on yours ????
Nothing to loose by trying i guess :)
I`d like some feedback on this if it does.
By the way this problem is known to occur after a power blackout or if the power cord or power bar is turned off while the set is playing.
Hope this help and good luck.
Posted on Mar 17, 2011
My lg tv is overfilled, it cuts people off on the top and cuts the bottom off. How do I get the picture to fit the screen
Its pretty easy check your remocon for the button that writes
ratio press it continiouly until you find the 16:9 ratio
hope you get it right
George (ratio button usually is on top right of you remocon )
Sep 22, 2016 | LG 47LG50 47 in. LCD HDTV
LG shows it will lose display in 3 seconds
hi the tv has detected a fault with the back lighting, now it could be a problem with the voltage to the back light or some of the leds in the back light have failed, it will turn off the back light when it finds a fault. behind the screen there is rows of leds on strips and they all light up when the screen is in use. and the main board knows they are lighting up by the voltage its using. when to many leds go out the voltage is too high so it will turn the back lights off to save them. also the same if the power board is not supplying the right volts. say the volts need to light the back screen is 64 volts and its only giving 62 volts the power is not right so it shuts down. same for if the volts go up to 64.5 volts it will do the same. hope this helps you under stand.
Jun 11, 2017 | LG 47 47LV5500 47 LCD TV
I have a 47 inch lg LED model 47LE5400-UC. The TV turn on, but just shows vertical lines. Does anyone know what may cause this or how I can fix this??? THANKS!
Hi, the main board of your TV is dead This can be cause by open fuses surface mounted you have to take out the mainboard and check for any open fuses specially from the main processor IC replace if you found any.you can also order a replace board at shoppjimmy.com just follow this link
search for brand and model good luck
Apr 06, 2012 | LG 47LE5400 47 in. TV
My 47" LG LCD TV
its no big problem.I implore you visit the user's manual to see how to zoom and undo it. Get back if you encounter further problems.
Jul 15, 2011 | LG 47 in. Flat-Panel LCD HDTV
Tv turns on and off by itself
Hi.Maybe your television have problem in power supply.I there it is loose connection at the power supply section located at the right side at the back of your television when you open the back cover.
Jul 02, 2011 | LG 47LC7DF 47 in. LCD HDTV
LG 47LE5400 loud POP, shuts down, immediately comes back on OK. Happened 4 times on two months. Dangerous?pman407@
That is interesting.
Only thing I can think of is electrolytic or other non-essential filter capacitors bursting.
It is hardly dangerous for you, but it is most likely dangerous to the TV itself.
I'd open and inspect the boards for signs of bust components.
Dec 09, 2010 | LG 47LE5400 47 in. TV
LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Jan 02, 2008 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
