Question about Sharp AR-5516s
Sharp AR5516 error code H4 - Sharp AR-5516s
sir fixalot
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
  • 990 Answers
SOURCE: code H4 comes up when the sharp copier ar-5316 is switched on
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Posted on Jan 28, 2009
  • 255 Answers
SOURCE: H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Posted on Oct 31, 2009
My copier sharp-ar5516 is indicating error code F5 00 what's problem
on your ar5516 f5 error code would be a copy lamp problem, lamp bad or the fuse or a connection.
Apr 11, 2017 | Sharp Office Equipment & Supplies
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Jul 09, 2015 | Sharp Office Equipment & Supplies
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5516 use to display h4, l1, h1, p1, u1, ch and i need the solutions to open them.
For H4 enter the following codes # interrupt C interrupt 14 Start button twice For ch check whether all the doors(side door,front door) are closed.
Jan 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have H4 error on my Sharp AR5516 copier. What should I do?
#Kintu Dennis Kentus
Aug 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Sharp AR-5516s Logo
484 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
