Question about Technics SA-EX300 Receiver
Stuck in tape monitor
My receiver is stuck in tape monitor mode. How do you get it off? I have hit Tape monitor button and every other button countless times and combination of buttons as well. Checked the manual and it only advises to press tape monitor to turn on and off. https://support.panasonic.co.nz/docstore/SAEX300%20Book.pdf
    Sergeant:
  • 256 Answers
There is a problem with the switch not Engageing with the circut board.
Posted on Dec 05, 2012
2 Suggested Answers
  • 4234 Answers
SOURCE: missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Posted on Mar 25, 2008
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
Mar 09, 2016 | Audio Players & Recorders
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
My kenwood receiver is on but no sound
Check that the tape monitor (or tape 2) is not on. To turn it off press the tape 2/tape monitor button. Turn the volume down first!
Feb 01, 2010 | Sony STR-DE325 Receiver
I have not been able to record LP's. The instructions mention hooking up the cables to the receiver outputs down to the TDK deck. Which outputs? Tape, Aux,? I tried splitting off of my phono outputs with...
your phono outputs are a whole diff ball of wax than aux or tape etc, whole diff signal, all that they should run to is phono in on the receiver. You are using the cd recorder as a tape deck more or less, so use tape out to line in on the tdk, and tape in from tdk output. so..when spinning record, you have receiver set on phono, and the tdk should also be receiving that signal, to playback you would hit tape monitor button on the receiver and hear what the tdk has done, or is doing.
Feb 01, 2010 | TDK DA-5900 2-Disc CD Recorder
Denon 2802 powers up, no soound, no trouble codes
Make sure you're not on tape/monitor mode. That happened to me one time. Seemed to be working just fine but there was no sound. Hit that button and it went back to normal. And this was after a half hour with the folks at Denon and their answer was it was broken and needed repairs.
Apr 13, 2008 | Audio Players & Recorders
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
Stuck Tape Removal
usually a reboot gets it out...hit eject button BEFORE windows starts up...I've seen some get stuck forever... Good luck.
Aug 22, 2007 | Quantum ValueLoader SDLT 320 Super DLT...
502 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
