Question about Delta & Single Handle Shower Faucet
Can't regulate a delta shower.
I have a delta combo bath and shower. We have a hard time to regulate the shower.
    President:
  • 2,976 Answers
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
Posted on Dec 13, 2012
heatman101
  • 43501 Answers
SOURCE: shower/tub combo hot water problem
There is a restriction in the faucet or the piping to the faucet on the hot wtaer side...this will be very hard to find and fix... The shower uses less water so it will get hot.... the tub spout allows more water flow so you cannot get the water more then warm...
Take the faucet apart and blow out all the passage ways with air... also run some water from the piping while the guts are out of the faucet, to flush the piping...
Hopefully this will fix you up...
Heatman101
Posted on Mar 04, 2010
  • 81 Answers
SOURCE: Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
Posted on Jun 01, 2010
  • 9 Answers
SOURCE: How do I turn the shower on? I just moved into a
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Posted on Apr 01, 2011
Ironfist109
  • 3018 Answers
SOURCE: Can't get both hot water running at the same
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
Posted on May 23, 2011
  • 19 Answers
SOURCE: I have a delta 1400
There should be a lever on top of the tub spout that, when pulled up, stops the water at the tub spout and redirects it to the showerhead
Posted on Aug 29, 2011
I have a delta 1400 series bath/shower and for the life of me, I can't figure out how to get the shower to work. I turn the knob to the left to adjust the temperature. However, I don't have an...
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
Aug 29, 2011 | Delta T13420 Chrome Classic Single Handle...
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
Apr 01, 2011 | Delta & Single Handle Shower Faucet
Need rough in dimensions for delta R11000
Wondering if you have you model number confused; the Delta R1100 is a shower flow diverter; see here:
diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641">http://www.faucetdirect.com/delta-r11000-3-6-setting-diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641
The installation guide and spec sheet is available for the above on the web page.
Currently available Delta Tissue Holders can be seen here:
http://www.deltafaucet.com/bath/accessories/filter.html#11051218525_
None of the model numbers are close to what you have provide. Perhaps you can pick out the model closest in appearance to yours. Links are available below each model for the dimensions and installation instructions.
Mar 01, 2011 | Delta Faucet Company Innovations Polished...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
I am haveing a problem putting my tub and shower faucet back need a daigram of it can find one online it is a delta tub and shower faucet can you help me james
The only thing that comes to my mind, go back where you bough them and
ask them to make some copies of the installation instruccions.
I know...the pride will get hurt a bit....but you will install this bath in NO time.
Hope this help
Mar 26, 2010 | Delta Faucet Peerless& Single Handle...
No hot water in bathtub
its called ur anti-scold system its installed in all single shower units to adjust remove the handle and will see usually a blue and red adjustment clips move the red so more hot water can be mixed in try the water adjust until comfort level is achieved
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Shower/tub combo hot water problem
Heatman101
Mar 03, 2010 | Delta & Single Handle Shower Faucet
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
143 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
