Question about Sony KDL40EX400 40 in. HD-Ready TV
Hi We bought a Sony Bravia 40" 2 1/2 years ago. Model # KDL40EX400. After about 14 months we started to experience something very bizarre. The TV would turn itself off. No lights on the screen. Af
    Top Expert:
  • Sony Master
  • 14,553 Answers
At some point you have to cut your losses, this is the reason I suggest getting an extended warranty with coverage (including the maker) of 3 years, 80 of the 140 sets in our shop are less than 3 years old, if this set had that they would have to fix or replace the set----One reason I choose to answer your question (I do this here for free) is this set ought to have a error buffer, when set fails it will count the event and that also indicates where the issue is.
Most of the Sony sets for the last decade with set off and using the Sony remote: Display, 5, vol down, and POWER will if set comes on bring up a display with a number of shortened items listed----they should all if the set has this be a zero. Any with a number indicates a issue and the number indicates the number of times this event has happened.
Posted on Dec 04, 2012
mistersony
  • 320 Answers
SOURCE: sony bravia KDL40S2000 standby blink four times
A 4 flash issue means either the back light inverter (power supply) has failed or that one of the fluorescent tubes in the panel has failed. The only way to know for sure is to check the fuses that are on the inverter board. If one or more of the fuses are opne, then it is likely the inverter board is bad. If the fuses all check good, then the panel is at fault. If it is the inverter board, it is a part you could replace yourself; the cost of the board is about $70. If it is the panel, you would probably want to consider replacing the TV, as the repair costs would be over $1000
Posted on Dec 10, 2008
  • 129 Answers
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
Posted on Jun 29, 2008
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
SOURCE: tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Posted on Aug 29, 2009
SOURCE: Sony XBR4 - 46 inch Double Imaging and 1/2 screen dark
Sorry not a solution...We also have exact same problem (TV about 1.5 years old) - out of warranty - all Sony told me to try was to un-plug TV for 2 minutes - useless. I am trying to decide if I should bring to service store to try to fix. I hate to spend a couple of hundred dollars to find out it costs $2000 - less then a new one. Anyone have any suggestions?
Posted on Oct 23, 2009
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
Jun 22, 2014 | Sony BRAVIA Televison & Video
Sony Bravia 3D Smart Tv
If your TV is a month old call sony and get the TV serviced or exchanged. You are covered under warranty.
Apr 11, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
Hi,i have a Bravia 40" 4500 Sony LCD TV. I have
Appears that you have an issue with the t con boardl It is reponsible for the image you see as well as any anomalies that appear. And you have your share!!! Go here for parts TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 15, 2017 | Sony Televison & Video
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Jun 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a sony bravia televison, screens cracked
Over here in southern California, Wii controller get thrown at the TV. Same kid problems.
Well, there is no way to fix the screen itself, only replacing the screen.
The part# for your lcd screen is 180205911.
I got that part# through Partstore.com. They had screens for that model KDL-40S2000, but the cheapest is $1,850. That doesn't make sense to me.
So, I googled the part# "180205911". Only one place has it is nexttronics.com
List price $1200, but the sale price is $650.
I googled the model# "KDL-40S200" and then clicked on "shopping". One place called SONY STYLE is selling the TV for $599.95
It maybe better and cheaper to get a new TV from them.
I hope I answered your questions correctly. Please rate me. :)
Feb 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL40EX400 40 in. HD-Ready TV Logo
210 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
