Visio E3D420VX Remote Control Does Not Work
No remote control works with the E3D420VX television. I have tried the remote that was shipped with the unit as well as a universal programmable remote provided by my cable company - remotes previously worked and now both do not. The remotes have not been dropped, thrown, or otherwise damaged in any way. Batteries installed are brand new and were tested on other items to ensure this (flashlight, other remotes, etc.) I tried setting the television back to factory settings through the manual on-screen menu and the remotes still will not work. I believe the issue may be system board-related or firmware. Cycling power does not work to reset this neither does completely unplugging the unit and resetting. Is there another way other to enable the remotes from the television side to power on the unit than to take this unit to an authorized repair shop?
  • jpittsforhom
    jpittsforhom Mar 21, 2013
    I contacted Vizio - they are sending a new IR chip. We'll see if this works *crosses fingers*
  • jpittsforhom
    btw - Vizio customer service was outstanding. I tried everything they suggested (I had also tried before I called) and still no response on the TV. At first they were just going to send me a new remote control but I explained that I had my cable box remote programmed so that it could control the televsion and the CSR asked if they both went out at the same time. I replied yes they did. Without any hesitation, the rep said it's the IR chip. Sending it now. I will let you know how the repair went.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If the remotes have been tested and ruled out and do not work at even very close range to the set I would suspect the remote receiver in the set is bad---
It is of course inside the set but has to be up front somewhere with a lens--not very large.
Understand that both the remote and the front buttons(or side) both go to the same place inside the set with the manual ones having priority over the remote===remote signal is infrared and is translated inside the set---both that signal and the buttons go to the microprocessor which does the actual work.
If remotes are good something between the lens on the receiver and the micro is bad, the receiver is the common failing point. Not really a lot of parts from where the signal comes in until the micro.
Posted on Dec 04, 2012
Testimonial: "Thank you for the reply. At least I know a little something more than what I had, which was almost nothing. I really appreciate your help."
3 Suggested Answers
fubar666
SOURCE: Code for digital remote control on Visio L15
Go here and click on the question about remote codes (they give several three, four, and five digit codes): http://www.vizio.com/FAQ.aspx#
Posted on May 21, 2009
SOURCE: Remote stopped working
frpm baldmeaney i unpluged my tv same model for 5 min and all was well again . this may work for you . good luck!
Posted on Nov 18, 2009
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
VISIO M470SL remote does not work. The remote is OK. Is it the IR sensor or the main board that needs to be replaced? VISIO M470SL remote does not work. The
If the standby light is ON at the front panel; when you power ON the set, and if the remote control is found OK too; the remote control sensor inside the TV is defective. Before doing anything, try by reset the set once.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 09, 2014 | Televison & Video
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
Dec 30, 2012 | One For All URC-9910 LCD Remote Control
Remote wont control TV Visio Eco1080
Check and replace the remote sennsor inside your Tv.
Mar 27, 2012 | Televison & Video
I need the code for my RCA RCR312W remote Control for a Visio Television
Hello
Setup codes for Vizio TV with RCA RCR312W remote control are:
11758, 10864, 10885, 11756
OK.
Sep 21, 2011 | RCA RCR312W Remote Control
We recently purchased a Visio lcdhd tv and the manual that came with our Jumbo uiversal remote doesn't show the code setting for the Visio. Is there a code you can give us.
We can't give you the code without specific model numbers for both the TV and remote control. Try the codes for the Visio models that are listed in the manual. There is a good chance that Visio used the same coding system for more than one model. If that doesn't work, check the Internet support page for your remote control. It may have additional models listed, and one may apply if Visio used one of the other remote control systems on the market at the time your remote control was manufactured.
Oct 27, 2010 | Televison & Video
Jan 08, 2009 | Vizio L15 Television
Need code for Visio VO37L 37" HDTV
Did you continue to go through the code search? Chances are there is more than one code in the remote that will work with your tv and may have more or less functionality. I would give that a try first.
Dec 31, 2008 | Brookstone 538744 Remote Control
Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Nov 22, 2008 | Vizio L37 Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
