Question about Sony KP-51HW40 51" Rear Projection Television
Possible thermal fuse problem.
Picture turns blue, then TV shuts off. Standby light flashes 8 times. I removed back panel and maintained room temperature @ 70 degrees. TV stays on longer.
I too, took off the back of my Sony TV after I started getting red and green shadows (called retrace lines) around words and people; and blew out all the dust inside hoping that would help. Ironically, I discovered that most problems with rear projection TVs are due to a malfunction located in the bottom FRONT panel, accessed by taking off the front speaker panel and then a wooden panel after that to access the circuitry, specifically this little black box with 6 screws on it. Go to www.SomeLifeBlog.com and this site has photos how to take off the front of the tv and instructions how to fix some common problems that repair people will charge you $300-500 to fix. This man, his instructions, photos, and website were a godsend. Good luck.
Posted on Jan 30, 2009
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My Hitachi L42VC04UB replaced a failed power board .The television comes on and after a short time it shuts down and the standby light in the front of the television flashes blue and red .This happe
Well either the TV's main (or other) board overloads the power board and it shuts itself off or the power board itself shuts itself off for whatever reason or the main board shuts off for whatever reason.
With the setup you have I'd say it's probably going to be difficult to figure out which one it is.
You will want to have yet another board - either main or power - to eliminate one of the two most likely possibilities.
What did you do with the original power board?
If you keep it you can probably send it to us for repair....or if it's cheap enough just buy another one.
i don't think there's an easier and affordable way to narrow it down than using a third board.
www.coppelltvrepair.com
Oct 08, 2012 | Televison & Video
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony plasma standby light flashes 8 X, won't stay on
when pluggin power it turns on and immediately move to standby
Dec 28, 2008 | Sony PFM-42X1 Plasma TV
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KP-51HW40 51" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
