Question about Kenmore 700 6972 Dryer
Does not start
Dryer doesn't start but can hear click
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Does it run if you hold the start switch in?
Posted on Dec 04, 2012
2 Suggested Answers
canwoodjc
  • 3301 Answers
SOURCE: My Kenmore 110.66962501 dryer doesn't start.
if your sure the thermal fuse is good,, check the start switch,, making sure the dryer select setting is set to something other than off, also, the door switch . you can Jumper both these switches, I'd try the door switch first as they go out more often . if you have a meter and want to test the switch Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
Posted on Jul 20, 2011
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Dryer turns on but doesn't tumble
  • If you can hear your motor spinning, then it is most likely caused by a broken drum belt.
  • If you can hear your motor 'humming' like it it stuck, then you might have faulty 'motor start capacitor'.
  • If you cannot hear the motor, then it maybe the drying controller board or sometimes the motor itself.
All cases involve dismantling the dryer and best left to a qualified dryer mechanics: check your warranty as the unit may still be under warranty (in which case, call the manufacturer help desk for instructions).
Hope the information helps!
Sep 20, 2011 | GE Dryers
The machine doesn't turn, but it just click when you push the start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2011 | Whirlpool GEX9868J Electric Dryer
DRYER DOESN'T DO ANYTHING. I HEAR CLICKING IN THE TIMER AREA WHEN HOLDING THE START BUTTON DOWN AND NOTHING ELSE. IS THERE A WAY TO BYPASS THE TIMER TO MAKE SURE THAT'S THE ISSUE?
heatman101
Sep 03, 2011 | Maytag Dryers
Went to dry clothes and the dryer doesn't tumble and all I hear is a click comming from the back of the dryer
heatman101
Aug 20, 2011 | Samsung DV219AE Dryer
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Kenmore 700 6972 Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
