Question about Tower Aloha Breeze Fan
Cleaning how do I clean this fan to get off old greasey grime does it come apart my mom gave me two of them but they are very dirty
  • SophieLee Dec 09, 2007
    I have unscrewed two screws at the back of the fan, but I am still unable to open it for cleaning. Can you please tell me more precise on how to unscrew the face? Thanks!
Cleaning the tower fan consists of this, i took the time to figure it out! unscrew top two screws on back of tower fan. then on bottom of tower fan is a screw cover,(pin size hole in middle of circle) pull cover off. unscrew hidden screw, and now with a little force it should pop right off. it exposes the filter and all it interior. front screen does not come off. oh yeah,your welcome!
Posted on Dec 31, 2007
  • SUSAB
    SUSAB Dec 03, 2013
    THANKS WILL TRY THUS
    Genius:
  • 1,074 Answers
If you have a phillips screw driver,unscrew the face.use a 2in clean paint brush dip in alcohol and remove all the grease from off the fan.upon finish use a soft cloth to dry.then you set it up back.good luck.
Posted on Jun 17, 2007
How to find a window fan that can be taken apart to be cleaned
I use this kind as a window fan and it’s great and easy to clean. Very inexpensive too.
Nov 16, 2017 | Miscellaneous
Have a very dirty oven will it catch on fire when i use the self cleaning setting
I would scrape and clean has much as you can,from the oven,then turn your self cleaning oven on.Make sure your fan is on above the stove.the oven pretty much bakes the grime off at a high temp take your racks out before turning your oven on..much bakes the grime off
Nov 05, 2011 | Hotpoint RB757 Electric Kitchen Range
Why does a table fan slow down after some time?
Revolving blades in table fans pushes out air towards the front by creating a vacuum at the back of the induction motor. Other than providing air flow, the gush of air also cools the motor. Over time, esp if used in a polluted surrounding, dust collects inside the motor and causes friction in the shaft. If left for a prolonged period, this friction causes heat eventually drying up the lubrication, causing breakdown in the motor amature windings and also a leaky starting capacitor, thus slowing down rotation and also a complete failure.
2. Fans must be regularly taken apart, cleaned and lubricated. It is fairly easy if you are willing to learn. My India made Usha brand table fan is 48 years old and is still running smooth - just changed the start capacitor last year and my National ceiling fans are more than 35 years old.
3. In fact all moving parts in any equipment must be periodically taken apart, cleaned free of dust and grime and freshly lubricated. It will outrun your lifetime and serve the next few generations.
Best Regards,
Mahathev of Malaysia
May 29, 2010 | Cfm 802 Ecofan Table
Glass inside oven door is dirty. How does one clean it?
If the grime is on the side toward the oven you can use easy off oven cleaner. If the grime is in between the two pieces of glass you will need to take the door apart to get at it. If you need to do this second step get back and i will talk you through it
Jul 31, 2009 | Kitchen Ranges
Dim lighting.... my mom gave me this tv after winning if from work (a smoke filled casino/bar) when they were re-modeling. i think it is really dirty and thats what is making it so dark and dim. also it...
i have a similar tv same size 1998 but mine was bought froma nasty house that had riches that **** all inside the tv and it stinks horrible i have the same priblem as u
Jun 11, 2009 | RCA P52926 52" Rear Projection Television
Dont clean my dishes
Try cleaning out your drain because it could be clogging up and this can cause it not to clean the dishes.
May 19, 2009 | Tappan MDB531RF Dishwasher
Blows warm air
you need to disassemble the rear fan shroud and clean the back of the condensor. If the compressor runs and the lines are cold, it is dirty. The rear condensor is the one discharging the hot air. Both sides must be clean and free of dirt/grime
May 06, 2009 | Sunbeam Heating & Cooling
Dirty self cleaning oven
easy off has a new spray for self cleaning ovens start with that after getting loose grime then self clean
Oct 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
Tower Aloha Breeze Fan Logo
2,032 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
