Question about Coby Electronics Corporation Coby MP827 8 GB Flash Portable Media Player
Coby mp827 sdhc card
Will a sdhc card work in this device or do I need a sd card specifically? Also, how many gigs can I get (8, 16, 32)
  • 32,281 Answers
This player uses a micro SD memory card.
You can download the manual from this WEB site.
http://www.manualowl.com/m/Coby/MP827/Manual/247614
Posted on Dec 04, 2012
  • 1 more comment
  • mystormygirl
    mystormygirl Dec 10, 2012
    I know it takes a microSD card, but can I use a microSDHC card, the manually doesn't say that.
  • Chris Hingee
    Chris Hingee Dec 10, 2012
    SD cards can not be bigger than 2GB and are slower compared to SDHC which stands for Secure Digital High Capacity. Not all the equipments that use SD cards can use SDHC cards. You need to check with Corby.
  • mystormygirl
    mystormygirl Dec 16, 2012
    thank you for clearing that up.
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Does not work with 8mb memory card. Why not please? Canon A540. Problem occurs when change a 2mb card for a 8mb card. Have not tried anything to fix problem
The A540 is designed to work with SD cards. Your 8GB card (I assume you really mean gig, not meg) is actually an SDHC card (SDHC stands for Secure Digital High Capacity). While SDHC cards will fit into SD slots, they will not work in SD devices. You need to keep using SD cards, 2GB and smaller.
Aug 23, 2010 | Canon PowerShot A540 Digital Camera
I just bought an hp 4 gig sdhc memory card for my kodak easyshare c743 camera. Will it work or should i return it?
The C743 works with MMC and SD cards, not with SDHC card. Your 4GB card will not work in it. You can return it or, if you have another device which can use SDHC cards, keep it.
Jun 29, 2010 | Kodak EasyShare C743 Digital Camera
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
Will my Canon SD600 suport a SDHL flash memory card?
I assume you mean SDHC.
The SD600 was designed to use SD cards. The SDHC specification is backward compatible, meaning that SD cards will work in SDHC devices, SDHC cards will not work in SD devices. This is a hardware incompatibility, not updatable in firmware.
Sorry, but that's just the way it is.
Feb 24, 2010 | Canon PowerShot SD600 Digital Camera
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Feb 23, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Coby Electronics Corporation Coby MP827 8 GB Flash Portable Media Player Logo
145 people viewed this question
Top Coby Electronics Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Coby Electronics Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
