Question about RCA D52W19 52" Rear Projection Television
How do you use the pip/swap buttons....
I have a 52 in RCA projection screen tv, but I do not know how to use the pip/swap buttons. I lost the user manual in my move. Or do you know where I can download a user manual for my RCA tv?
Thank you.
    Problem Solver:
  • 5 Answers
Go to rca.com , click tv then click support, drop menu size then drop menu model #and you can download user guide
Posted on Jan 25, 2009
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
How do i get the pip, Picture in picture to work ??
If it has the feature buttons on the remote for it, swap, position etc.
Some older sets have to have signal routed to one of the rear video inputs for a source for the PIP. Newer sets have two tuners--one for main and one for PIP---if pulled up the swap will switch one picture for the other--some allow both on the screen at same time side by side.
Read the owner manual to see if the set has PIP.
Jun 12, 2012 | RCA P52960 52" Rear Projection Television
Just moved, can't find booklet....need book to set up TV
To find your user's manual just in case you've lost it. You can visit http://tv.rca.com/en-us/productdownloads.html and select your tv's size and model number. In case you don't know the tv's size I'll give an example. On the back of the tv you can find the model number. Example mine is R52WH74, that means that my projection screen is a 52 inch. Write back if this isn't what you're asking for.
Jensenka
Sep 30, 2008 | Hitachi Televison & Video
RCA D61W130 tv
this unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
OWNERS MANUAL FOR RCA
owners manuals or user guides are availble online at rca.com
Jan 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound gone on tv big screen guideplusgemstar
this you forget the MUTE buttom on the remove control?
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
RCA PIP
Put something else, DVD player, VCR or a second signal, into one of the other inputs on the unit and switch the PIP to watch that input...
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
190 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
