Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
Washer will turn on however this dl code keeps coming on after washer
gets started
  • tobias904 Jan 11, 2009
    where could I get the door lock assembly replaced
  • 8,197 Answers
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Posted on Jan 11, 2009
  • Jyackle5
    Jyackle5 Jan 11, 2009
    Call sears or an appliance repair place
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello.. I don't have a lot of time.. to work on this.. but wondering what the dl error codes is on a kenmore elite oasis washer model 110.27086603 serial #CT4070587
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27086603&pathTaken=partSearch
The DL code points to a Door Lock problem.
See the Whirlpool Service Manual for their Cabrio washer (basically the same as the Sears Oasis).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and testing procedures.
Apr 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine keep flashing dl and that keeps the door from locking
Error code DL means door lock failure. Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis Elite HE washer. I keep
Sep 11, 2009 | Kenmore Washing Machines
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,070 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
