Question about LG 32LB9D TV
LG picture options grayed out
I wanted to adjust the position and size of my screen because the top and bottom are getting a little cut off, but I discovered I cannot go into the "Screen" submenu to access those options. Color temperature and XD are also grayed out. I've tried every aspect ratio, picture mode, and reset the picture to factory settings, and have not managed to fix my picture problem or access those options. Everything I've got (Roku, Dish DVR, PS3) is hooked up with HDMI cables. The screen cutoff affects all of them.
5 Suggested Answers
  • 86 Answers
SOURCE: Picture is cut off at top and bottom
Push the "Ratio" button on the remote
Posted on Jan 22, 2008
  • 458 Answers
SOURCE: edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Posted on Jun 30, 2009
  • 318 Answers
SOURCE: My 42 - inch LG
On the remote control there is a zoom button. Your picture is zoomed in x2. You need to set it to normal.
Posted on Jan 23, 2011
CheriT Dish
  • 146 Answers
SOURCE: I just purchased a 37"
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. Since you have already set the aspect ratio on your DISH receiver to the correct option the next step to try is changing the format. You can do this by pressing the (*) format button on the DISH Network remote, you should be able to cycle through a few different options to find the best one that fits your TV. If this option still does not fit the TV the way you want it to the only option left is to change the format options on the TV itself in the TV menus. You may have to refer back to your TV manufacture or the TV manual in order to do this. I hope you find this information useful and if you have any further questions please let me know.
Posted on Oct 25, 2011
Tv screen resolution
Check your menus. There should be one menu that allows you to resize the picture to the screen size. (Most likely a submenu in the video menu).
Jun 14, 2017 | Samsung LNT5265FX 52 in. LCD Television
Picture cut off for my flat screen pansonic tv, zoom adjustment grayed out and i cannot adjust?
Without that model number (should be on receipt or owner manual for set) do not expect anything here other than a general answer.
If the zoom is grayed out it may be normal depending on what is connected and how. If you are using a box of some kind hooked via rear inputs the box may be the reason---it may control or cause this to be grayed out---a simple answer to a question: Do you have the same problem with a DVD etc hooked up to a rear input?
Apr 18, 2012 | Panasonic Televison & Video
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
The picture is oversized and the printing as in the stock ticker or in the sports scores can only be seen a little bit on the bottom. Can't find anyway to resize the picture.
Zenith sets, like most others now, are adjusted electronically through a service menu. You'll need your original remote control (or a Zenith-brand universal replacement with a MENU key) to access the menu. Press and hold the MENU button until the channel number and time display goes away, then press 9, 8 , 7, 6, ENTER. This puts you into service mode.
In service mode, CHANNEL UP and CHANNEL DOWN move through the different settings, and VOLUME UP and VOLUME DOWN change the values. Make sure you write down the original value of anything before you change it so you can put it back if necessary. One of the reasons the manufacturers hide the service menu is because the set can be damaged by incorrect settings to some of the parameters.
On some models, you can't get to all the parameters unless you change one called F MODE from 00 to 01. You might need to do this on yours.
The list of parameters varies by model and features. I haven't worked on a Zenith in a long time so I don't remember exactly what yours says, but you want to find two settings for V SIZE (vertical size) and V POS (vertical position). Adjust the size first by lowering the value until the top and bottom of the screen are black. Then adjust the position so the picture is centered (black strips close to equal size). Finally, increase the size until the picture fills the screen again. It's normal to adjust for a little overscan, meaning you push the top and bottom a little bit out of view. If you stop too soon, on some channels you might see flashing lines at the top of the picture.
When you're finished adjusting, turn the TV off to exit service mode. If you needed to change the F MODE setting, put it back to 00 first. Your picture should be properly sized after all this.
Mar 19, 2011 | Zenith SY2772DT TV
Please tell me lg factroy setting codd
I don't understand your post. About what settings you wants to get it to its factory settings or its lost password problem!. If the password probelm,
If you ever forget your password, key in '7', '7', '7', '7' on the remote control
If picture settings must be set to factory settings do the following.
Reset is unique to each function: Manual config., Position, Split zoom, PIP position
and sub picture size for double window.
- Use the Reset option to initialize the adjusted settings.
Press the MENU button and then use [up/down] button to select the SCREEN menu.
2. Press the [=>] button and then use [up/down]button to select Reset.
3. Press the [=>] button.
• You can initialize Position, Split zoom, PIP Transparency, PIP position, PIP size
Mar 15, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
The sides of the screen are cut off
Please try using the Auto adjust functionality on the LCD TV unit itself.
Jan 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
LG 32LB9D TV Logo
230 people viewed this question
Computer Repairing
Computer Repairing
