Question about Dryers
Where do i find the igniter and thermostat of my maytag centennial gas dryer?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
VOTIT
  • 2071 Answers
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
dragonsthatk
  • 547 Answers
SOURCE: gas dryer burner won't stay lit on maytag dryer
thermo cupple need's to be replaced
Posted on Feb 17, 2009
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
Posted on Mar 14, 2009
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
GAS DRYER WORK FOR MINUTES AND THAN STOPS!
Posted on Apr 19, 2009
My Maytag Centennial gas dry is not heating up.
Need to know model number. Several items can cause this. Safety thermal, also known as thermal fuse, this is most common problem. Igniter or gas coils.
Dec 29, 2016 | Maytag Dryers
Centennial gas dryer. Why is there no heat?
On a gas dryer, a common cause for no heat is failure of the igniter. You can go to www.repairclinic.com and enter Maytag and model number to see a list of replacement parts and perhaps view a video showing the repair process.
Dec 17, 2015 | Maytag Dryers
Sometimes heat is working and then gets cool
Check the igniter in the bottom. It probably is starting to fail.
Sep 12, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
I have a Maytag Centennial gas dryer and the dryer will not turn off when the door is opened. I'm assuming this is due to a broken switch on the dryer door. How can I repair this?
door switch is correct you will need to unplug the dryer and open the cabinet open and replace switch, this website will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 11, 2011 | Maytag Centennial 7.0 Cu. Ft. 6-Cycle...
Maytag dryer model medc400vwo not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 31, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My centennial dryer (model medc400vw) won't start
I would bypass the door switch and see if it starts.
Aug 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag LSG7800AAW Dryer not working
Its Either One Of Two Problems If Its Electric Its The Thermostat but if its gas it can be either the thermostat or the igniter. If its gas you can watch the igniter or listen to hear if its lighting. If it lights its the thermostat cause if the thermostat is malfunctioning it will turn the gas off when it doesn't detect the flame. It turns the gas off to prevent your home from filling with gas. Hope this helps.
Thanks For Choosing Fixya
Sincerely,
Michael Scott
Jul 07, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Dryers Logo
Top Dryers Experts
