Question about Maytag Ovens
Some of my button on my oven wont work and some does. I changed out the control board and still not working.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
4 Suggested Answers
SOURCE: Oven wont work
it could be the over temp state positioned at the back top right hand side
Posted on Sep 16, 2009
marka19
  • 1430 Answers
SOURCE: I have a Magtag wall oven MEW6530DDS model. The
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Posted on Sep 18, 2010
  • 32 Answers
SOURCE: I have a whirlpool double oven mod GBD 307PDS10.
Try removing the ribbon connector and cleaning the end that plugs into the microcomputer. You can rub it lightly with an eraser or use electrical contact cleaner on it.
Posted on Jan 13, 2011
Replaced control board and keypad but oven buttons still not working
I pulled the schematic there is a thermal fuse on the neutral wire going to the control you should have 120VAC at terminals P4-3 and P4-1 if not find the fuse back trace from P4-1
Feb 12, 2014 | Whirlpool Ovens
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Start button wont work on whirlpool oven control panel
If it's just this one button not working, or a group of buttons (depending on the model) it could be due to:
1. Door switch or temperature sensor problem preventing the oven from "starting" -acts like the button is bad but is being locked out by some other problem sensed by the control board.
2. Bad keypad
- We sometimes see a problem due to oxidation or corrosion on the keypad membrane connector. If you are comfortable working on such things, we posted a procedure that you can use to clean off the oxidation. Here's the link, check under the "Ovens" section:
http://fixyourboard.com/techzone.html
3. Control board problem.
We repair these at www.fixyourboard.com
If you want to email us the full model number at info@fixyourboard.com maybe we can help you pinpoint the problem.
Oct 05, 2009 | Stoves Ovens
Can not alter temprature from fixed setting
to decrease or increase temp we use a button or switch and this switches reach order for control board as a general basis so if the tow functions - & + faulty together then i think it is the control board need to change
Jul 09, 2009 | Neff B4540 Stainless Steel Electric Single...
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
LED display says door. The control pannel wont work at all.
My problem has been repaired by my husband. I do not have the self cleaning on my oven yet the control board thought my self cleaning was on and the door was open. He had to jumper a wire between a connection on pannel to confuse the code and cause the board to set a new error code that could be reset. Which we were able to set the EO code and follow procedure for power disconnect and the board rest. We now have an opperatioal oven. Thank you .
Nov 23, 2008 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
