Question about Cisco Computers & Internet
ERROR MESSAGE SECUTITY ALERT THE IDENTITY OF THIS WEB SITE ON THE INTERGRETY OF THIS CONNECTION CANNOT BE VERIFIED
SECIRITY ISSUES MUST HAVE SOME HOW CHANGED AND NOW I CANNOT CONNECT AND HAVE THE SECURITY ISSUE AS WELL PLEASE SOMEONE HELP
    Problem Solver:
  • 30 Answers
Check the date and time in the router and computer are correct.
Posted on Jul 09, 2014
  • 193 Answers
SOURCE: actiontec router Outbound Traffic Blocked - NAT out failed
k first delete all temp files and cookies and clear history>and change teh dns to global one>i hope that u pinged with the web site have u tried ping with the ip address of teh web site>then here the way to change teh dns to static
start-->control panel-->and network connection-->right click on local area conn-->properties-->and high light the TCP/IP-->and click properties and u can see a dialog box>in that look @ the left side down u can see obtain DNS sufficx>and use the current following DNS select that and the DNS range is
4.2.2.1
4.2.2.2>and apply and ok>and reboot the pc>and check with teh web site iam sure its a dns issue>and rate me solved if its help full thx
Posted on Nov 04, 2007
2Gigs
  • 141 Answers
SOURCE: Wii connection issues.
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
Posted on Mar 13, 2008
SOURCE: Cannot connect to McAfee web sites from Centurytel.net
I don't have a solution, but may have more information - I am having the exact same problem, but with a different router (linksys wireless g router and a cable modem).
I am unable to access any website with "mcafee" in the url on one PC, but can connect from another. Running tracert from the "bad" PC to www.mcafee.com times out at the local network (192.168.1.1). All this leads me to believe that the problem is tied to a local virus. There is no network-level keyword restriction, visible or hidden, confirmed by accessing www.mcafee.com from the good PC through the same router/modem.
Hope this helps.
Posted on May 11, 2008
LASITHA-VEGA
  • 428 Answers
SOURCE: Cannot Connect - Validating Identity?
http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/mfc260c_eu_as.html?reg=as&c=au&lang=en&prod=mfc260c_eu_as
This is gonna help you. Please rate the answer :)
Thank You
Posted on Jun 15, 2009
kenpem
  • 7 Answers
SOURCE: I'm not able to connect my Lenovo laptop with my
Temporarily connect to the router with a cable and reconfigure it to use a different wireless channel. While you're there, this is a good time to change your security mode - WEP is dangerously weak and you should switch to WPA unless you have a very good reason not to.
If all else fails, there's a reset switch (hidden inside a hole) on the back of the router.
Posted on Oct 12, 2009
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Close the account and did not know
Security Alert! Message resent! Please verify your account by careNOT RECND A MESSAGE
Mar 07, 2014 | Zynga Texas HoldEm Poker
Security Alert! Zynga Poker sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to pana_st@yahoo.com. We recommend changing your Facebook...
I only asked for the greatness of your heart, if i can open a your account, will you give me 30% form your chip ?, if i can opened your account .Thx
Jun 17, 2011 | Zynga Texas HoldEm Poker
Hi when ever i open any site on my pc there is an error massage showing that secure or non secire site.....how i get rid from this and sec problem is after some time it show ss an error which is dont send...
- Naresh try to check the System Time if it is the exact time within your region
- Unsecured website issues usually determines the system clock of your computer
- upon changing the correct time restart the computer and try another website it should work this time
May 15, 2011 | Computers & Internet
Security Alert zynga poker Message Code: CA1
Remove Security Alert CA1-CA7. Just Open Intruction ->
http://error-codes-zynga-poker.besaba.com
Jan 29, 2011 | Zynga Texas HoldEm Poker
Error code 81000306 cant sign in
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13932.entry
Please go and read the solution right there.
Hope this helps.
Aug 18, 2010 | Microsoft Windows Live Messanger
Computers & Internet Logo
24 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
