Question about Indesit WA 115 Front Load Washer
Wia111 can you turn off at front of washer so the green light goes out
  • Indesit Master
  • 3,463 Answers
Turn the on/off knob to the position with the symbol I enclosed by a broken circle,.
This should turn it off.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
My indesit washer wia111 starts to wash but once it has done the main wash and goes to rinse the machine stops working and the red door lock indicator goes off
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into and run the program to finally drain shut off and open lock. . If this does not happen then the voltage at the valves,motor and pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 26, 2011 | Washing Machines
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Hp pavilion 513n tries to start up then turns off
This is a case where something that is getting switched on during start-up is causing the power supply to fail... probably due to a short. How ever I believe the short is in the power supply
This is an older HP model ( I have a 530N) with teh same problem. I bought a new power supply and installed it.
Aug 14, 2009 | Computers & Internet
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Indesit wia111 no lights come on when switched on at powerpoint
Make sure you dont have it set to soak. if you click the timer one click at a time, does the wash/mach. do anything like wash:spin:drain etc. check that door latch for power out once closed. difficult to diagnose without all the facts
Jan 27, 2009 | Indesit W 123 Front Load Washer
It starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Dec 11, 2008 | Indesit W 123 Front Load Washer
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Wia111
First check whether your inlet valve is open on the wall; if that is not the problem check to see that the inlet valves are not clogged with some dirt or something, clean out and refit. Plug off the wall and careful with the water spillage. The final part should be to check whether the water flows into the machine, ie. the entry at the soap dispenser. Simple.
Sep 01, 2007 | Indesit WA 115 Front Load Washer
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
143 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
