Question about Sharp Actius GP22W Notebook
Beeping Sound While Booting
While booting Laptop give an Irritating Beeping Sound as if a key from the keyboard is depressed whereas not! Again, it always indicate that a 256 external memory cache is installed which is not. Pls Stop this noise.
    President:
  • 2,961 Answers
Could you check that the time is correct when you next boot up, as sometimes a beep on startup can indicate a cmos problem, as you may have a flat cmos battery on the motherboard, and the system will keep losing the saved settings.
Posted on Jun 08, 2007
Keeps beeping at boot
beeping in some computer is a factory installed indicator for a malfunctioning part on your computer. One possible issue on your laptop is a stuck key on one of your keyboard keys. Have your keyboard keys checked. If the issue is in relation with the universal charger, the laptop may not be recognizing it at first boot due to incompatibility with your laptop or the charger itself is damaged. Have them checked by a local technician to avoid further damage.
Oct 19, 2014 | Fujitsu Siemens Amilo M7400 Laptop...
Emachines el1352g-01w beeps while booting up
be sure nothing on you keyboard or pressing any key
Dec 04, 2012 | eMachines EL1352G-01w (884483537679) PC...
How to stop the beeping sound
Beeping sounds when you try to boot up? Is your system booting up all the way? Beep sounds help the technician isolate the problem with your computer booting. Beep sounds normally indicate a problem with the memory, cpu, keyboard, fan, motherboard, etc. The number of beeps can be looked up based on the motherboard brand or bios and it will tell what the problem is.
Mar 18, 2012 | Dell Computers & Internet
Acer extensa 5620 starts booting with a beeping sound . any way when some keys are pressed the beeping sound stops and the copmuter performs normally.
This is likely caused by a stuck key somewhere on the keyboard. A computer's BIOS will beep repeatedly if it is receiving too much input when booting, like if you were holding down a letter key while starting up. By pressing other keys you're probably breaking the repeating input which is why it stops beeping and works normally.
My recommendation would be to check all of the keys on your keyboard to see if any of them are stuck down or generally sticky, or if any of them appear damaged in any way.
If they are not, it may be a problem in the connection from the keyboard to the laptop's motherboard, which would likely require the laptop's keyboard to be replaced, which can be a tricky process. I definitely advise consulting a professional to do a repair like that.
Hope this is helpful!
May 09, 2011 | Acer Extensa 5620 Notebook PC
It wont cut on keep making a beeping sound
beeping sound means that you have a bad power supply. Normally when booting your laptop, the power supply supplies enough power to boot to the operating system. You consult HP to replace your power supply in your laptop.
Oct 19, 2010 | HP OmniBook XE3 Notebook
WHEN I SWITCH IT ON IT KEEPS BEEPING LIKE A BUTTON IS PRESSED DOWN
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Dec 15, 2009 | Compaq Armada E500 Notebook
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Selecting booting device
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
'stuck key' on IBM ThinkPad 390E (2626-DOU)
goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Feb 10, 2008 | IBM ThinkPad 390X 2626 Notebook
Sharp Actius GP22W Notebook Logo
237 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
