Question about ASUS P4S533-X Motherboard
System panel connector diagram - ASUS P4S533-X Motherboard
  • ASUS Master
  • 3,606 Answers
Hello download the manual from here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4S533-X&p=1&s=15
First select your windows.
Select the manual folder and hit global for download.
Unzip the file when downloaded.
You need adobe reader to read the content.
The manual should be very detailed.
Good luck
Posted on Dec 04, 2012
2004 mini cooper blower fan motor
You just have to look at a new motor online to see that it has only two pins in the connector. Removal is another story. I have pasted the procedure from Autozone.com below.
Removal & Installation
Before servicing the vehicle, refer to the precautions section.
Disconnect the negative battery cable.
Drain the cooling system.
Discharge and recover the A/C refrigerant.
Remove the instrument panel by removing or disconnecting the following:
Battery box
Intake filter housing
Heater hoses
A/C pipe from firewall fittings (plug openings)
Heater locating stud nut
Steering column from steering gear
Steering column from rubber bellows
Left and right A-pillar trim
Radio
Cover from beneath center controls
Left and right kick panels
Connector behind left kick panel
Upper connector from blower control
Instrument panel end covers
Bolts behind end covers
Lower section of steering column trim panel
Electrical harness from instrument panel trim
Connectors on steering column
Heater connector
Lower bolts on instrument panel support (next to steering column lower end)
Instrument panel
.Disconnect the fan motor wiring harness.
Remove the fan motor.
To install:
Install the fan motor and connect the wiring harness.
Install the instrument panel in reverse of the removal procedure.
Refill the cooling system.
Reconnect the negative battery cable.
Evacuate and recharge the A/C system.
Check the coolant level after starting the engine and running for several minutes.
Jul 25, 2017 | Mini Cars & Trucks
I dont know how to connect the h.d.d led, the power sw,and the power led,back to the motherboard
just see the motherboard manual or circuit diagram on cpu cabinat.find attached snapshat of front panel of motherboard to plug back front panel connection.
Feb 26, 2013 | eMachines Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    I lost the connection's posisition of front power switch on my MS 7309, can you please send me a diagram of connections. thanks...
    1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
    2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
    Note: The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
    Hopefully this information helps.
    Thank you for using Fixya.
    Aug 05, 2011 | Computers & Internet
    Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
    I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
    This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
    This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
    If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
    As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
    You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
    Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
    Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
    Hi u can easily solve this problem.
    open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
    mukesh_ibm@yahoo.com
    May 12, 2009 | ASUS Computers & Internet
    Wiring diagram to hook-up remote starter on 1996 dodge caravan
    Constant 12V+ Red or Pink/Black - Ignition Switch Harness
    Starter Yellow - Ignition Switch Harness
    Ignition Dark Blue - Ignition Switch Harness
    Ignition 2 Black/White - Ignition Switch Harness
    Ignition 3 Dark Green/Red - Ignition Switch Harness
    Accessory Black/Orange - Ignition Switch Harness
    Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
    Neutral Safety Wire Black/White - Power Control Module
    Brake Switch White/Tan - Brake Switch
    Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
    Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
    Head Lamp Green/Orange - Light Switch
    Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
    Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
    Door Lock White/Dark Green - BCM at Fuse Panel
    Door Unlock White/Dark Green - White Connector B58 Connector
    Horn Wire Black/Red - Steering Column
    Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
    Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
    Your R/S instructions should tell you what goes where.
    Thanks for using FixYa - a FixYa rating is appreciated!!
    Jan 31, 2009 | Vehicle Parts & Accessories
    Need diagram for 2007 escape audiophile
    if it is the wiring diagram for the Escape you need, here it is:
    12 VOLT CONSTANT Connect to BATTERY ONLY STARTER TAN/LIGHT BLUE (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 LIGHT GREEN/PURPLE (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) WHITE/BLACK (-) @ SJB, Connector E, Pin 4, See NOTE *1 PARKING LIGHTS ( + ) BROWN (+) @ SJB, Connector C, Pin 19, See NOTE *1 POWER LOCK PINK/WHITE (1-Wire System) See NOTE *2 @ SJB, Connector D, Pin 22, See NOTE *1 POWER UNLOCK Same wire, See NOTE *2 See DIAGRAMS DOOR TRIGGER PINK (-) @ SJB, Connector C, Pin 28, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN YELLOW/LIGHT GREEN (-) @ SJB, Connector A, Pin 14, See NOTE *1 TACH NOT RED or WHITE/RED @ IGNITION COIL or FUEL INJECTOR WAIT TO START LIGHT N/A BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DARK BLUE/LIGHT GREEN (-) @ SJB, Connector D, Pin 3, See NOTE *1 ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER EXTRA INFORMATION NOTE *1 The SJB (Smart Junction Block) is the FUSE/RELAY BOX on the PASSENGER SIDE of the CENTER CONSOLE. NOTE *2 This vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 1000 Ohm Resistor and UNLOCK requires a straight (-)Negative
    Jan 06, 2009 | 2005 Ford Escape
    ASUS P4S533-X Motherboard Logo
    44 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
