My Printer model is Canon MP276. Thhe alarm light is turn on and my computer could not print because it say that there is a paper jammed. There is absolutely no paper jam. Any Solutions?
The amount of ink and paper are sufficient.
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Posted on Jan 05, 2009
balkonskij
SOURCE: I have an MP210 Canon
Hi! have canon pixma mp210
i had the same problem E 3
and service button on
and B and C blinking(okay they are always blinking at my printer because i recharge it with syringe).
The cause of the problem was bad inserted paper -> paper jam
First i checked paper tray -> found a syringe fragment
opened the printer cover-> found a small peace of paper
but the printer was still blinking with E3 !
i began to disassemble the printer(be careful with a small secure part on the front side under control keys..i have broken this s it:) )
than i saw no other pieces of paper there.
i decrease the clips where the paper goes through(white plastic stuff) and put a sheet of paper there and started the printer again!
solved!
ps maybe it is better not to disassemble the printer and put in some way the paper between the rotating pulleys(because the printer had this paper jam and wants to have paper there to give it out)
copyleft balkonskijorg
Posted on Jan 12, 2009
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
Black ink printing on back of paper
Your paper feed rollers have some black ink contamination: wipe the rollers, all around, with slightly moist tissue paper until there are no more ink evidence coming off the rollers. To moisten tissue, warm water with a very small amount of Windex, dish soap or rubbing alcohol does wonder.
Also clean gently around the bottom of the print head assembly to remove any obvious splatters.
Hope i helps.
Sep 26, 2011 | Canon PIXMA® MP530 All-In-One Printer
Tip
How to improve quality with the right paper setting
One of the most common reasons for complaints about ink-jet output quality, is that the driver is set for the wrong type of paper. Different papers require different amounts of ink and different proportions of ink colors to produce the correct final colors. Setting the paper type tells the driver which color tables to use. Some ink-jets are supposed to recognize the paper type automatically, but the feature doesn't always work. So if you're not getting the results you expect, don't give up on the printer until you've made sure you're setting the driver manually for the paper you're actually using.
on Mar 25, 2010 | Office Equipment & Supplies
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
Hp deskjet 940c does not print, blank paper goes thrugh. Computer conction is right, ink ok ( not flushing lights) and clean.
Hi you need a new black ink. it may be empty or faulty.
The machine dos not measure the amount of ink in the tank it only counts the amount of squirts you have used normally its only a problem with refiled inks
if this is useful please rate me thanks Ian
Mar 08, 2011 | HP DeskJet 940c InkJet Printer
How can I cure streaking on the reverse of the paper? Epson S20.
streaking on the reverse side suggest dirty rollers.
1. remove cartridges form the printer
2. disconnect all cables
3. check full paper path for presence of debris, lint, bits of paper, remove if necessary (you can put printer on it's back or sides for esy removal)
4. mount on long skewers lint free clothing or tissue
5. wet tissue/cloth in isopropyl alcohol and whipe all rubber rollers on paper path till no discoloration to the tissue
6. connect all cables
7. insert inks and print test page
if necessary, you need to clean rollers again, but once is usually sufficient. to keep printer in good condition, you need to print at least one page per week and periodicaly clean the rollers, that depend on amount of printing done.
Jul 28, 2010 | Epson Printer
Makes all sounds like printing from computer command, but paper comes out blank. Sufficient ink in all cartridges.
Try cleaning your inkjet ports as per your owners manuel. At times ink may dry up in the port clogging it so no ink can get thru when printing.
Aug 31, 2009 | Office Equipment & Supplies
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Ink
set the print quality to normal from best. if on normal then set it on draft.and click-- apply--- after you set without fail.
Aug 07, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
401 people viewed this question
k24674
jasbo
jasbo
