Question about Panasonic CT-2788YD 27" TV
Tv has shadows around edges of the picture - Panasonic CT-2788YD 27" TV
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Is it possible you could take a photo and post it here?
Posted on Dec 04, 2012
I have a red ghosting problem on my TV.
set should have magic focus. use it or adjust convergence manually.
Dec 09, 2014 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv screen is warped on edges. what to do?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I have a new bulb but am getting a dark shadow around the edges of the picture. The bulb seems fine, but the shadowing is covering about half the screen. Any ideas?
The light tunnel under the colorwheel has collasped. This is a major repair. I have known some to glue the tunnel back together, but it requires patience and skill and the right kind of glue....
Jul 10, 2010 | InFocus IN24 Multimedia Projector
There is a line, like a shadow on the right side of the screen all the way up and down. What is that from?
Your TV uses a "Light Tunnel". A part which has various filters to create the proper "color" of light needed to produce the picture. Sometimes, one of these filters slips, causing a shadow to appear in a corner or along an edge. The appearance is this defect is more of a shadow and does not have a sharp, defined edge (like a letterbox image would). You can replace the entire light engine to repair this or just replace the light tunnel. The light tunnel repair is much more difficult... I would recommend a service call, as this is not a simple procedure. I hope this helps.
Mar 17, 2010 | Samsung 61" Slim-Depth DLP HDTV
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Red and blue shadows on my sony wega
hello it sound like convergance chips might be the trouble
shaun
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The Tv just got a green ring around the edge of the picture
If this is a TV with a CRT (glass tube screen) then this pattern will be caused by a residual magnetic field in the shadow mask (the metal bit at the front behind the glass). Normally when a TV is turned on from cold a set of wire coils demagnetize (or degauss) the set and clear these patterns. If this circuit is not working you will have to take it to a repairman and get him to do it manually (or the shadow mask in twisted). In future handle the set with care and keep it away from strong magnetic fields (vacuum cleaner motors, etc).
Dec 21, 2008 | Televison & Video
"melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
Jul 10, 2008 | Polaroid Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Panasonic CT-2788YD 27" TV Logo
13 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
