Question about Sta Rite Pool & Spa
I have a Sta-Rite Max-E-Pro centrifugal pump with integral trap that was installed march 17, 2011. Yesterday, the pump began making a noise. Called pool co, they came out and said bearings were burned up and entire motor would have to be replaced. Does this sound right?? Thank you, Gina
  • Sta Rite Master
  • 1,338 Answers
Yes and no, the motor might be rebuilt about $75 . you need to know how many gallons your pool is, screened in or solar heat and ask your local pool pump motor repair guy with free testing, if you have the right size pump for your pool, if so can the motor be repaired. jay
Posted on May 30, 2013
  • 3 Answers
SOURCE: tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
  • 6 Answers
SOURCE: Pump noise
sounds like it needs new bearings, take it to a pool professional.
Posted on Jun 09, 2009
thepool
  • 78 Answers
SOURCE: Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Posted on Apr 19, 2010
  • 64 Answers
SOURCE: I have a Hayward Max-Flo II pool pump and it is
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
Posted on May 29, 2010
  • 366 Answers
SOURCE: How do you replace a seal on a Sta-Rite pool pump?
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Posted on Aug 16, 2010
Testimonial: "Very helpful thank you for your time."
What is a Sta-Rite Max-E-Pro Pool Pump impeller
take off silver band clamp that will separate the motor from the wet end remove the plastic piece on the side with the motor impeller is inside check to see if glogged use a stiff piece of wire to clean out
Aug 08, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Overheating problem with Max E Pro P6E6E-206L
this can sometimes be attributed to a supply power problem. Undersized wiring or inadequate amperage.
It can also be caused by an oversize impeller. Make sure the impeller matches the motor horsepower, you can oversize the motor but cannot use a bigger impeller than what the motor is rated for. Also, make sure you have adequate voltage/amperage coming to the motor.
Check for loose connections as well. Wow, I'm all over the place on this one, sorry.
Hope it helps.
Apr 06, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Yesterday I had my heater converted fro LP to Natural gas (technician replaced orifice). Now heater makes loud whistling sound when burner is on. Stop making noise when heater is turned off and only blower...
The wrong orifice was installed. Sta-Rite changed their blower configuration 3 years ago. Heaters older than that have a flat orifice that works with the older style blowers. Newer heaters are equipped with a tapered orifice. Mixing a flat with a new blower causes whistling. Mixing a tapered with an old blower causes whistling. Good luck!
Nov 17, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Pool & Spa Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
