Question about Honeywell Universal 7-Day Programmable Thermostat RTH7500D1031
Would like to know if I will be able to install a Honeywell RTH7500D1031 with my gravity furnace. I have upload pictures of my current thermostat and furnace. Please let me know if you need more information about my equipment. I am concerned due to age furnace that I may have better luck leaving it as is. Pictures of them/furnace http://imgur.com/a/uO6kw
Yes if there are only two wires they should be a red wire and a white whire the red wire goes on the new stat where there is a R and the white wire goes where there is a W thats it put the batteries in the new stat and set the time and date and turn it to heat and turn it up to 80 it should work if the wires are not color coded just put one of them to the R and the other to the W dont worry you can't shocked it is low voltage good luck
Posted on Dec 04, 2012
It shows current temp lower than what is programmed. Even when set to temporary, the furnace is not kicking on. All doors shut on furnace, any ideas?
There can be several reasons for this, the thermostat may be working fine but the heater or furnace may cause a lapse in response.
Nov 28, 2015 | Honeywell Programmable Thermostat Heater
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Non programmable Honeywell to programmable
the 230 doesnt sound compatable with your system. you are gonna need a t stat that is compatable with Heat Pumps.
Mar 18, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Universal 7-Day Programmable Thermostat RTH7500D1031 Logo
142 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Brandon Berry
Brandon Berry
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
