Question about Speed Queen SWFT71 27" Coin Operated Front-Load Washer with 2.84 cu. ft
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Posted on Dec 04, 2012
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
mhamlin63
  • 138 Answers
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Posted on Jun 29, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
  • 84 Answers
SOURCE: SWFT71
Did you replace the striker on the door, or the door lock mechanism?
Try adjusting the striker on door.
Posted on Jan 12, 2010
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
We have coin operated washing machines is there a sheet to show us how to change the price
http://www.pwslaundry.com/c-295851.4-commercial-speed-queen-swfx71n3000-front-load-washer-parts-for-repair-service.html
You want the one that says Programming...
Dec 31, 2012 | Speed Queen Swfx71_N3000 Commercial...
How to break speed queen coin machine
why do you want to brake your washer for in the first place any way
Nov 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
I have a 1999 Ford Explorer Eddie Bauer. The multiple cd changer is stuck. Won't load or eject. I can hear and see one of the cd trays going in and out. It cycles every time I start the car. Mike
does it have the change holder in front of the changer? if so, there may be a coin lodged inside the changer. if you have a flat piece if metal, such as a piece of backstrap, you can slip it beneath the cartridge and remove the magazine. once the magazine is out, check to see if there may be a coin logded in the bottom of the changer.
Mar 19, 2010 | Car Audio & Video
SWFT71
Dec 28, 2009 | Speed Queen ATS90AWN Front Load Washer
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
STUCK CD CHANGER
A coin has fallen down inside the unit. If you unbolt it from the arm rest and turn it upside down,the coin may fallout. I had to take my apart and physical remove the lodged coin.
Jan 10, 2009 | 2000 Lincoln Continental
Coin is stuck inside
where is this machine? apartment complex? YOUR private machine?
Dec 27, 2007 | Maytag MAH2400A Front Load Washer
Speed Queen SWFT71 27" Coin Operated Front-Load Washer with 2.84 cu. ft Logo
267 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
