Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
Connecting RCA plug to speaker wires
Can I connect Sony Model SS-RG440  (6 ohms sor watts, ?) bookshelve speakers to my Sony TV Model KLV-S32A10?   Also, on the back of my TV I have  red and white Audio Out female plug terminals.  Is this where I plug in the RCA plugs?  Before doing this, is there going to be enough output from my TV to drive both speakers without additional amplification? I'd appreciate any help.  Thanks.
A. Van Houten
    Sergeant:
  • 227 Answers
You can connect the RCA plugs to the speakers. But, as for using the red/white Audio outputs you may need an amplifier, those connections are used when going into a dvd or vcr that boosts the signal in their own environment. If you have a connection for headphones on the TV you might have better luck there for the speakers.
Posted on Jan 11, 2009
My speakers is100 watts which stk I'm going to us for the my radio and it's two speakers each one is 100 watts my radio is Sony TA-V715
The watts of the speakers are not too important when connecting to an amp. With large wattage speakers such as yours the amp will drive them. What you only need to worry about is someone turning the volume up to much, but only if the Sony amp can deliver a greater wattage than the speakers. If it can it will destroy the speakers at the highest levels.
However when connecting speakers to any amp, you must look at the Ohms of the two items. You must NEVER connect a speaker of lower Ohms to an amp of higher Ohms than it. Must amps and speakers will fall between 4 to 16 Ohms. If your amp says 4 ohms you can connect just about speaker to it. But if says 8 Ohms, you must not connect any speaker rated lower than 8 Ohms. Connecting a 4 Ohm speaker to an 8 Ohm amp will destroy the output transistors of the amp.
Nov 05, 2016 | Sony Audio Players & Recorders
Can I replace the speakers on this system? Speakers are too large for space & want to replace with another brand.
make sure impedance is the same so 6 ohms and the power rating of speakers is no less than 200 watts peak rms.And bare wire ports on back of speaker.
The power rating is so the speakers can handle the maximum power delivered by stereo amplifier without burning out speakers coils.
Jan 23, 2016 | RCA Audio Players & Recorders
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
What is the remote code for this tv Sony KLV-S32lA10
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Feb 24, 2011 | Sony KLV-S32A10 32 in. HD-Ready LCD...
What is the best way to connect two 4 ohm type-r
Connecting the speakers in parallel is the best route here. Parallel wiring is simply connecting the positive wires together and connecting the negative wires together. Then connect both positive wires to the positive output of the amp and both negative wires to the negative output of the amp. When both 4ohm speaker are connected in parallel the combined impedance is 2ohms. This particular amplifier has a damping ratio of >250 at 2 ohms compared to a damping ratio of >1000 if you connected them in series at 8 ohms. the damping ratio is simply the reduction of power transferred. (For future reference in order to get the maximum power transfer input impedance must match the output impedance.)
Jul 24, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Want external speakers for Sony TV Model KLV-S32A10
This is really easy. A pair of simple bookshelf speakers will do nicely. Simple speaker wire can be run to them, to extend whatever cable they have. If it's only screw terminals they have, so much the better.
You'll have to attach RCA plugs to the ends going to the TV, but that's easy.
Jan 04, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
220 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
