Question about Dr Mercola Way Healthier Home Air Purifier Replacement Lamp Module: 1 unit
Way Healthier Air Purifier stopped working
I hadn't used the unit for a couple of years. I started using it again but it doesn't seem to be working. I replaced the lamp module (not cheap) but it still doesn't work. Does any one have any ideas of how to get it working again? It seems to be a very simple machine with few parts. Thanks.
When I attempt to turn the unit on, the display flashes but wont stay on
The main circuit board is bad. The circuit board can be repaired with a one year warranty. Call (336) 499-2505 for more information.
May 23, 2012 | Ecoquest Fresh Air Air Purifier
Hi I've had my ionic breeze quadra silent air purifier for approximately 6/7 years. I must admit I haven't used it for approx 2/3 years as it does not light up. I changed the fuse but still...
Pull the element out and take a moist cloth and clean it out. After it is completely dry put it back in this should do the trick. If this helps please rate me and do a testimonial
May 17, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
I have bought Ionic Pro Turbo Air Purifier recently in USA and moved out of the country after the purchase. When I plugged in with right electricity voltage & watts, my purifier starts with green light...
Hi Sathish, I work for the Ionic Pro company. What country are you trying to use the unit in? This will help me determine how to assist you. Thank you, Mary
Feb 15, 2011 | Ionic Pro TURBO Air Purifier
MyFresh Air Air Purifer is not working. About 1 year ago I accidentaly put a staple through the power cord to the purifer and it stopped working. I have had it in storage but would like to start using it...
You can use any standard computer power cord for this purifier. If the damage is closer to the plug side of the cord, you could cut the plug end off and put on a new replacement plug. You should be able to find a replacement cord or plug at a hardware store. Hope this helps you.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
I purchased my purifier about 3 years ago but it has only been in use for maybe the last 2 years and it just stopped working. When I plug it in and turn it on nothing happens? I dont think for such a...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse for the ozone part it is marked F21 on the same board
Aug 22, 2010 | Ecoquest Flair Air Purifier
Ionic breeze smells like a serious electrical short when I turn it on.
THEY RUN WITH A DIFFERENT KIND OF SMELL PEOPLE ARE NOT USED TO. ITS A HIGH VOLTAGE SCARY SMELL .IF IT SEEMS TO WORK OK THAN IT MIGHT BE OK
Apr 23, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Jul 07, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ecoquest Fresh Air Purifier Quit Working
My husband came home and checked out the unit. He discovered that the cord was bad, so he replaced it with one we had. It works fine. The cord plugs into the unit at one end and into the wall at the other end. There was no rewiring needed. Problem solved!
Aug 04, 2008 | Ecoquest Fresh Air Living Air Purifier
Venta LW24 stack failure.
I have the same problem. Must be defective units. Have only had mine a couple of years.
May 30, 2008 | Venta - Airwasher LW44 Air Purifier
Dr Mercola Way Healthier Home Air Purifier Replacement Lamp Module: 1 unit Logo
Top Dr Mercola Air Purifiers Experts
Are you a Dr Mercola Air Purifier Expert? Answer questions, earn points and help others
