Question about Brother XL-5130 Mechanical Sewing Machine
I have a brother xl 5130 sewing machine. The needle broke and when I undid the screw to replace it the hook that holds the tread away from the needle broke into pieces so I need to replace the needle holder but don't know where to purchase one. I have been to a few places but no one seems to know where to get one can you help?
  • Brother Master
  • 7,365 Answers
Check with these 2 sites,,call them or email them about the part
sewvacdoctor.com
or
a1sewingmachines.com
Posted on Dec 04, 2012
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
SOURCE: needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Posted on Dec 15, 2009
DianeB715
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part). The above info that was previously posted was almost dead on for me. The screw spoken about is called a set screw, which is a screw that is almost hollow. To lossen or tighten a set screw you use an allen wrench. The one on this machine is 5/64 th size. You can use a very small screwdriver if it fits tightly, but you must be careful not to strip the inside of the screw.
Posted on Dec 20, 2009
Tally Girl
  • 1133 Answers
SOURCE: borrow sewing machine from sister unsure how to
you need to go to this webpage http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_xl5130eus&dlid=&flang=English&type2=-1 and download the instruction manual for this model. It has the threading up instructions plus selecting stitches, winding a bobbin etc.
The thread breaking is most likely due to incorrect threading up of the top thread. I suggest that if you can, you print out the manual, put into a little folder and place beside the machine and refer to it often. Follow the instructions in it on winding a bobbin, putting it into the bobbin case correctly and threading up the top thread. Make sure the bobbin goes into the case the correct way, as per image.
Remember, ALWAYS THREAD UP TOP THREAD WITH THE PRESSURE FOOT RAISED, this keeps the tension discs open so the thread can seat into the tension device correctly. And you must get the bobbin thread into the tension spring fully and then place the bobbin case into the shuttle using the little latch so it stays in place.
Also, new needle for every new project, and put the needle in "flat shank to the back". It will take standard domestic sewing machine needles 705/130H but it is important to select the correct sized needle for the fabric you are sewing so that the needle can penetrate the fabric but not leave big holes. So for light weights like chiffon you want a size 60 or 70. For medium weights a size 80 and for heavy fabric like denim or a coat weight wool you would use size 100. Ball points for stretch fabrics so that the needle pushes between the fibres and a regular point for woven fabrics.
I trust this helps you out, 4 thumbs up if so. Thank you.
Posted on Jun 28, 2011
The presser foot on the brother xl-5130 has fallen off
please send me a picture and I will gladly assist you with all the help you may need ;)
Nov 20, 2013 | Brother XL-5130 Mechanical Sewing Machine
Camp that holds the needle on the needle bar came of and cannot get it back on
You should be able to slide it from the bottom and push it in upward position and turn the screw to tighten. Hope this helps!Jimmy
Mar 28, 2012 | Brother XL-5130 Mechanical Sewing Machine
I need a needle clamp with screw for brother Xl 5130. do you know wherre to find it?
check with these websites
sewingpartsonline.com
sewvacdoctor.com
sewforless.com
Aug 17, 2011 | Brother XL-5130 Mechanical Sewing Machine
The little thing that the needle goes into broke. How can i get a new one and what is it called? I have a Brothers machine XL 5130
it's called a needle clamp-check sewingpartsonline.com
on the left hand side click on brother parts
go down till you find your model number there is a brother xl 5130
it's close to the bottom of the page
please rate this with the thumbs in upper right hand corner
Aug 09, 2010 | Brother XL-5130 Mechanical Sewing Machine
Part that holds needle keeping falling out breaking needle
Tighten screw with a nickel or penny, does not slip like screwdriver.
Jul 22, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
95 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
