Question about Epson Stylus CX7800 All-In-One InkJet Printer
Dirty head on an epson cx7800
Smudges on the paper as if the print head is dirty. how do you clean the print head??
SOURCE: Scanner stopped on my Epson Stylus CX7800
DON'T BUY EPSON..
Posted on Jan 30, 2008
SOURCE: epson epl6200l photoconductor dirty
when i am printing a small dots black appear.. what is the problem? photoconductor unit? were can i buy one here in the philippines?
Posted on Apr 11, 2008
Metawatch
  • 96 Answers
SOURCE: Does not print
The CX series printers use a pigment based ink, and if it dries it frms a semi hard gooy substance on the printer ink input pins.
Sometimes after the insertion of new cartridges (Ensuring the yello tab is removed) and letting them sit overnight (to soften the ink blob) and running several cleaning cycles can unblock the ink "jam". Note: Epsons printer head need ink to cool them when printing (Sort of like oil in a car) so don;t try to print withot having ink flowing to the heads. It can also ruin the print head by overheating.
If all else fails there are several companies that sell inkjet cleaning solution. You may need a couple of cartridges to flush blocked jets but if will most likey work if the print head is still functional.
Otherwise, the technican is correct, you may need to purchase a new printer.
Note; For the future... Never let the ink run out of any cartridge without immediately replacing the cartridge. Never remove an empty cartridge without replacing it immediately.
Posted on Jun 20, 2008
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
While printing in black, why are there faint ink smudges?
It could be the "clean print head" sponges. The area under where the print head sits is where the ink go during the head cleaning cycle. They can become saturated with ink and smear onto the print head and then onto the paper.
Mar 14, 2016 | Epson WorkForce Pro WF-4630 Wireless Color...
What is wrong with my Epson R280 printer when the ink appears smeared down columns of a spreadheet
Probably dirty heads on the nozzle. In most inkjets there is a maintenance option to clean the heads. I would first clean the heads, and then make sure that the print heads were aligned. If that is all squared away then check for any driver or firmware updates. Finally get some rubbing alcohol and gently clean the print head. Sometimes if the printer is not used that often the ink will congeal and smear.
Oct 19, 2014 | Epson Stylus Photo R280 Series
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
There are black ink smudges on the bottom corners and edges of my color prints on velvet fine art paper. How can I stop that from happening. I already cleaned the heads twice. The prints are great...
The R2400 has an option to load paper on-top (Epson calls it the Automatic Document Feeder) and at the back. Based on the printer's User Guide the Velvet Fineart Paper should be loaded at the back. (Epson called is the Manual Single Sheet Feed).
Look at the User's Guide availabe on their website.
Jan 19, 2010 | Epson Stylus Photo R1800 InkJet Printer
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Epson cx7800 paper continually comes out - not printing
you need to download the scc to reset your printer if you can not find the software let me no and will give it to you
Oct 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson CX7800 print head not working
it would be better if you get a new printer or the best to use is vodk and leave it over night to get rid of all the dryed ink
Aug 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
White bands on my prints
Did you try cleaning the decoder strip? It is located behind the print head, looks like the tape inside a cassette tape. If it has ink splatter or a smudge on it carefully wipe it down with a paper towel (damp). It may be easier to remove it, careful not to stretch the little spring on the left side.
Dec 14, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
