My machine wont start, it switches off then comes back on at the end cycle
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • melissa444
    melissa444 Dec 06, 2012
    simpson 45s558e Ezi loader 5.5kg
I have a code error on my fisher & paykel front loader washing machine code C on can someone advise how to fix. cheers in advance
try leaning against the door when pressing the start button. door/lid switches have a habit of failing or getting out of adjustment
Sep 06, 2015 | Fisher Washing Machines
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
Top load washer when you start cycle no water and it starts to agitate does it on all cycles
Hi, It could be faulty timer, the knob you turn to select cycles(programs) or faulty water level switch, the knob or button you select the water temperature, or size of water level, it depends on brand of machine. check water level switch by lifting top of machine, you will see tub, look at back you will see a small tube coming from wiring harness, where controls are, that tube comes from switch to connection on side of tub, remove tube from tub connection, wipe it, put in your mouth and blow air into it, you should hear a click sound whenever you blow into it, sometimes could get stuck, connect tube back to tub, manually fill with water, just a little above half, then start machine from the beginning of any program, let it complete to the end, then try it normally to see if it does the same thing, if it does, you will need a mechanic to check timer and pressure switch. good luck.
Aug 06, 2009 | Washing Machines
Washer stopped and wont turn off
Unplug the appliance from power, or trip the circuit breaker and cut power to the appliance for about five minutes.
While appliance is unplugged check that the drain hose is not kinked and empty water from inside the machine.
Let me know if you still have the problem when you connect the appliance back.
If the appliance does not start back, then there is a faulty part, in that case give me the model number as printed on service tag and tell me when the appliance had been purchased, also tell me the country of purchase.
Many thanks.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Machine won't start after opening door near end of cycle
Unplug the machine for about a minute. then plug back in. It restarted on its own.
Apr 29, 2009 | Washing Machines
Whirlpool Duet Washer Wont Drain
Sounds like a relay on the board. Have you tried to reset the machine by switching it off at the wall and leaving it for about 20 seconds before switching on again?
Oct 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
