Question about Dr Mercola Way Healthier Home Air Purifier Replacement Lamp Module: 1 unit
"Way Healthier Home Air Purifier" stopped working
I hadn't used the air purifier in a couple of years. I bought a new lamp module and it didn't work when I plugged it in. I put the old lamp module in and it still doesn't work. Does any one have any troubleshooting ideas? It seems to be a very simple machine. Thanks
The electronic circuit broken, lamp doesn't work
listed under air purifier,send to manufacturer
Jul 01, 2015 | Air Purifiers
Replace lamp biozone 1000
Here's some Biozone lamp info http://www.air-purifier.org/orderform.html. Replacing the lamp is pretty simple, just remove the old lamp and install a new lamp and fuse if any.
Aug 31, 2012 | Biozone Standard 1000 Air Purifier
When I attempt to turn the unit on, the display flashes but wont stay on
The main circuit board is bad. The circuit board can be repaired with a one year warranty. Call (336) 499-2505 for more information.
May 23, 2012 | Ecoquest Fresh Air Air Purifier
Can't find uv lamp in Fresh Air by ecoquest
The picture is a classic, with no UV light. Still works great. It got my kids off their inhalers after 15 years of 4 per month. Now 4 per year. A Fresh Air, depending on the age, has a light attached in the bottom of the visible base behind a cage and plate, and the new honeycomb units have the light inside the honeycomb.
Jun 22, 2011 | Ecoquest Living Air Classic Air Purifier
Hi I've had my ionic breeze quadra silent air purifier for approximately 6/7 years. I must admit I haven't used it for approx 2/3 years as it does not light up. I changed the fuse but still...
Pull the element out and take a moist cloth and clean it out. After it is completely dry put it back in this should do the trick. If this helps please rate me and do a testimonial
May 17, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
My Purifier just stopped working. I cleaned it & even tried a new outlet, help!!!
Hi.
Parts for the unit are not available anymore. In any case I suggest not repairing the unit. There had been health and safety issue related to this kind of purifier.
Here an article: Hi. Parts for this unit, including the filter are not on sale anymore, as all Ionic Breezemodels had
Aug 11, 2010 | Sharper Image Ionic Breeze 3.0 Air...
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ecoquest Fresh Air Purifier Quit Working
My husband came home and checked out the unit. He discovered that the cord was bad, so he replaced it with one we had. It works fine. The cord plugs into the unit at one end and into the wall at the other end. There was no rewiring needed. Problem solved!
Aug 04, 2008 | Ecoquest Fresh Air Living Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Dr Mercola Way Healthier Home Air Purifier Replacement Lamp Module: 1 unit Logo
42 people viewed this question
Top Dr Mercola Air Purifiers Experts
Are you a Dr Mercola Air Purifier Expert? Answer questions, earn points and help others
