Question about Brother XL-5130 Mechanical Sewing Machine
The piece that broke is on the left side of the needle. I need to replace the needle holder and don't know where to purchase a new one. I've been to a few places but no one seems to know
  • Brother Master
  • 7,365 Answers
Here is the phone of sewvacdoctor.com
(866)-855-2009
a1sewingmachines.com
ron@a1sewingmachine.com
Posted on Dec 04, 2012
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
DianeB715
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part). The above info that was previously posted was almost dead on for me. The screw spoken about is called a set screw, which is a screw that is almost hollow. To lossen or tighten a set screw you use an allen wrench. The one on this machine is 5/64 th size. You can use a very small screwdriver if it fits tightly, but you must be careful not to strip the inside of the screw.
Posted on Dec 20, 2009
  • 23 Answers
SOURCE: I broke a needle on something hard. After I
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Posted on Apr 13, 2010
Can't adjust tension
is it the right needle for the fabric being sewed?
you said you put in a new needle and as you tighen the screw
the needle moves to the left,, it's a possibility that the needle holder or
needle bar need to be checked because the needle should stay straight
and not move to the left unless your changing the needle position.
could the top thread be caught somewhere, like the spindle the spool
set on, I've had that happen, if possible take a can of air and blow the
tension disks just incase there is any lint in them.
Nov 05, 2012 | Sewing Machines
After replacing needle, needle threader won't work. What am I doing wrong?
You probably haven't inserted the needle fully into the needle bar. Try that first.
Also check that there isn't a bit of needle shank in the holder.
Good luck.
Oct 04, 2012 | Brother Sewing Machines
I've just recently purchased a new Brother 1034d . It worked perfectly to begin with but then i took out the left needle to experiment with Rolled edge stitch and on replacing the needles have not
you said you took out the needle, when you put the needle back in
did you turn the needle the right way as you were inserting it into the
needle holder
Aug 27, 2012 | Brother 1034D Mechanical Sewing Machine
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Janome 1600p-DBX is not taking the bobbin
have you checked to see if the needle is inserted correctly into
the needle clamp,,all the way up into the needle clamp
& that the needle is turned the right way
also check to make sure the bobbin is inserted correctly into the
bobbin case.
if you have checked for this then the following is possible
it's very possible that when you broke the needle that it caused
the machine to jump time, & it would have to be taken to a sewing
machine shop to be retimed.
Aug 01, 2012 | Janome 1600P-DB Mechanical Sewing Machine
I have a Toyota expert ESP 850 embroidery machine. While embroidering, the presser foot will become loose and the needle will then hit it and break. I've gone through three needles and I don't want...
Change the needle socket holder, See www.datastitch.com for new needle socket holder.
We also buy toyoa machines used in any condition
larry@datastitch.com
Jul 01, 2012 | Sewing Machines
Elna Lock L1 won't keep thread chain
for a manual try elna customer service
as for the needle, check to see if it's inserted correctly in the needle holder
the needle must be pushed all the way up into the needle holder--
the flat side goes to the back side of the machine
you also mentioned that you broke a needle, when a needle is broken some times it can cause the machine to go out of time, which means it has to be taken to a sewing machine repair shop & be retimed,,
and it needs to be serviced.
Mar 01, 2012 | Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
I have a janome 1 step sewing machine and it keeps jaming. I have been sewing a thicker fabric recently with no problems, but now it jams after about 3 revolutions. I think something is wrong with the...
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, I think yours has a top loading bobbin inside a magnetic bobbin case so this info should work for your model. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room to work).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Apr 13, 2011 | Sewing Machines
Brother XL-5130 Mechanical Sewing Machine Logo
51 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
