Question about Canon PIXMA MP150 All-In-One InkJet Printer
Help, lines have appeard accross my prints.
I believe it may be head alignment, but I have lost my users guide.
  • 741 Answers
Whenever lines begin to appear across the top the cartridge is no longer set properly. Take cartridge out and then re-set back in. That will take care of it.
Don't forget to rate this solution.
Posted on Jan 11, 2009
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
ALIGN PRINT HEAD FOR EPSON STYLUS C120 PRINTER
Here is a link to the user guide from Epson. There is instructions there on how to align the print head.
http://files.support.epson.com/htmldocs/sc120_/sc120_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Dec 05, 2011 | Office Equipment & Supplies
I have lost my users guide and cannot figure out how to align my printer head. Please Help!! Thanks in advance :)
Make sure that A4 or Letter size plain paper is loaded in the sheet feeder. Access the printer software. Accessing the Printer Software for Windows, Click the Maintenance tab, then click the Print Head Alignment button.
Follow the on-screen instructions to align the print head.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Office Equipment & Supplies
Http://img189.imageshack.us/i/93955650.jpg/ When you print a photo, color blue will be out on the first print. Why be like this?
You can find support for your print quality problems in your User Guide here:
http://support2.epson.net/manuals/english/ij/stylusphotor390/use_g/html/trble_3.htm#S-01200-00600-00200
I believe your problem is with vertical misalignment or banding.
Make sure the printable side of the paper is face up in the sheet feeder.
Run the Head Cleaning utility to clear any clogged ink nozzles.
Run the Print Head Alignment utility.
Clear the High Speed check box in your Advanced printer settings.
Make sure the paper type selected in the printer driver is appropriate for the type of paper loaded in the printer.
Links to help with the above solutions are available in the on-line Troubleshooting section under Print Quality Problems.
Feb 03, 2011 | Epson Stylus Photo R390 InkJet Printer
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I keep getting this message when I try to align the print head. An error occurred during automatic print head alignment. Press the printer's RESUME button to clear the error. Refer to the user's guide to...
The print head is the carriage that holds the ink cartridges and has tiny nozzles on the bottom that spray the ink on your paper. The nozzles have to be aimed (aligned) either automatically, or in WinXP with the following manual process:
1 Left click on the start button
2 Open "Printers and faxes" on the Start menu.
3 Find your printer on the printer list and right click on it once.
4 Select "Properties" from the pop-up menu.
5 Click on the "Maintenance" tab at the top of the new window.
A selection page for all sorts of upkeep items is then shown. Manual alignment of the print head is one of the choices.
Jan 23, 2009 | Canon i860 InkJet Photo Printer
LIGHT UNIFORM STREAKS ACCROSS PRINT
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Lines on printed photos
Hi Have you tried cleaning the printer and doing a alignment for the inkjets? I believe under your printer properties you should have the option do to maintenance clean and alignment>when doing this it will use some ink but in order for the printer to function properly you sometimes have to do this. Hi hope this helps you!!
Dec 04, 2007 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
