How to fix unable to format disk in enclosure?
  • 27,725 Answers
If this is an error message you are getting ?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
Hope it helps.
Posted on Dec 04, 2012
  • ricardo omandam Dec 05, 2012
    thanks sir for the suggestion i see the error "the device \Device\Harddisk1\DR3, has a bad block." and also "The driver detected a controller error on \Device\Harddisk1\DR2." I'm using windows 7 ultimate, I also tried the diskmanagement method and the command prompt method for formatting but it doesn't continue the process. Hope you can help me again sir.
  • Brian Sullivan
    Brian Sullivan Dec 05, 2012
    If this is your primary hard drive with an operating system you will have to format it using a third party disk and change the boot order to boot from the cd/dvd drive. If its not getting recognised you wont be able to format. To try to fix the driver issuehttp://download.cnet.com/slimdrivers-fre... This will automatically search for and find the correct driveryou will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
How can I reformat the hard disk on my dell optiplex 9010?
reformat only the hard disk? remove it buy an enclosure put it in enclosure plug on another computer and format there.
if you want format with installation just put the windows installer and format there.
Sep 07, 2014 | Computers & Internet
...UNABLE TO CLEAN error code 50'' my printer is
The hard drives are in a USB externa enclosure, set up as RAID 1 and are formatted as Mac OS Extended (Journaled). I do not save any TM back ups to them and they work after a restart and then sometime later start to provide the error message anytime I try to save to them. A restart usually fixes the issue for a finite period of time. Disk Utility runs and tells me the disks are fine. I never have trouble accessing data from them.
For more help visit cbrtechsolutions
Sep 03, 2013 | Brother DCP 165C Compact Color Inkjet...
How to format and use new USB storage device
if its not your primary drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
May 14, 2012 | Computers & Internet
Format harddrive
What OS are you using?
In Windows, go to the disk management utility and see if the disk is listed. (In Win 7, this is Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions.) For XP and Vista, the directions are similar but do differ a bit. Look at the bottom of the window, to see the list of disks. (Disk 0 is your main hard disk; do not reformat this by accident.)
Assuming the disc is correctly connected to the enclosure and is seen by the computer, you should see it listed as a removable drive. Note: you may need to change the USB port. The MX100 is an enclosure for 3.5" hard disks and needs the AC cord plugged in as well.
You may want to connect and turn on the enclosure when the computer is off, then turn it on. Then turn on the computer. This will hopefully allow the USB drivers to note the new device.
For the Mac OS, look for the Disk Utility.
If you still don't see the drive, check that the cover (and plugs) are completely seated. (Turn off the enclosure first.) Try the hard disk in another enclosure or a USB/SATA hard drive adapter. (If you have a desktop with a free SATA data port and power connector, try connecting the disk directly to the computer. (You need to determine if the enclosure is faulty or the disk itself is bad.)
I hope this helps. Please add a comment with your OS and if you see the disk in the disk management utility, if you need additional assistance.
(This enclosure will work with older versions of Windows, back to Win98Se. However, I don't believe all of those versions came with disc formatting utilities. In that case, you would need a third-party partitioning software (Partition Magic, Paragon Partition Manager). If this disk was in another computer and you want to save the data, try copying the data before reformatting. This may be easier to do with the USB/SATA adapter or the direct connection to the motherboard of a desktop.)
Apr 17, 2012 | Antec MX100 Aluminum Hard Drive Enc e
The light is on but the hard drive is not being recognized on the computer or the tv, it was dropped only once. there is a humming sound but no response. no more pictures or movies. is this possible to...
Good Day Daniellevion!
Have you seen a hard disk inside your computer? That is exactly what is inside in an external drive.
You mentioned that you dropped the external drive once, and that could be the reason why your computer was unable to recognized it as external drive.
Danielle! The connectors of the hard disk inside the Samsung External Drive (or other term is hard disk enclosure) might be loosened.
If you can open the enclosure and expose the two connectors, disconnect them and reseat properly.
That might fix it!
Jun 12, 2011 | Samsung G3 Station Desktop External Drive...
Starting yesterday, I've started to have this problem: "You need to format the disk in F: before you can use it" now what's odd is that it's been working fine for two years, now suddenly it's...
This can happen when a drive has become corrupted.
Try connecting it to a different computer, but if that doesn't work:
You can try to reformat it by right-clicking "My Computer" -> Click Manage -> Click on Disk Management -> right-clicking on the F: Drive and choosing to Format.
It will wipe all the data but may get it working again.
Mar 02, 2011 | Iomega 34579 1 TB USB 20 Hard Drive
I have the seagate 500 gb p/n 9nk2AL-510 and I went to go use it the other day and say that the usb port on the back of it has come loose. I am unable to plug a usb into it now. Is there any way to fix...
Purchase a new "empty" enclosure, and "transplant" the disk-drive from inside your enclosure into the new enclosure. Cost will be $30 to $40, but all your files on your disk-drive will be accessible.
Dec 16, 2010 | Seagate 500GB Desktop External Drive ...
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
The drive is not listed in
Try a replacement USB cable first, and test the LaCie on a different computer, to ensure the fault is on the external storage unit, and not a computer system problem.
There are two possibilities:
The LaCie USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. New Lacie are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be LaCie.
Check if your LaCie is Sata or PATA (IDE) before buying the enclosure.
Oct 20, 2009 | LaCie 250GB External USB2.0 7200rpm 250 GB...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
