Question about Scotsman C0330SA 1B 300 lb Cube Ice Machine
MY SCOTSMAN ICE MACHINE CO33O FREEZING CYCLE IS TOO SHORT AND IS MAKING THIN ICE
    New Friend:
There is usually a sensor that the cubes will touch after the cubes thickness builds to a certain point. This sensor should be adjustible.
Posted on Dec 04, 2012
  • LUIS Dec 04, 2012
    Thanks Jeremy, I will try that tomorrow.
  • LUIS Dec 04, 2012
    would you know where to find a troubleshooting guide online for this machine.its a scotsman prodigy C0330SA--1A . Thank you much for your help!
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Short freeze
Ice is to thin. Check to make sure water inlet valve is not letting water go through valve during freeze cycle. Make sure condenser coil is clean and condenser fan is running. Check the hot gas valve to make sure it is not bypassing during freeze cycle.
Apr 15, 2014 | Scotsman C0630MR_HD30B-32 684 lb 30"...
Scotsman cme256 as-1d sticks in harvest cycle
The only thing that tells the machine that a harvest cycle has completed and takes it back into a freeze mode is the ice level control. when the machine go's into a harvest the ice drops through the ice level control and brakes the beam and switches the machine back to freeze cycle. Pull the the ice level controls and replace them. if there is nothing wrong with them than it is the electronic controller. part number for ice level controllers are 11-0540-21. The part number for the control board is 12-2838-24
Dec 07, 2013 | Scotsman Kitchen Appliances - Others
Code 8 blinking machine making very thin ice?
Short freeze, thine ice.
Cause: Grounded ice thickness sensor.
Solution: Check sensor for dirt and position. Clean and adjust gap to evaporator surface using 13/64" drill bit as a gauge, lay flat between evaporator plate and ice thickness probe and adjust 1/4 screw 1/8 of a turn clock wise at a time after every harvest cycle. You don't wont the ice any thicker than 13/64 or thinner either. If you are still having problem after cleaning probe then replace it but you will still have to adjust the probe.
Aug 08, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman cme306
Here video. Was long freeze error. found out that it was bad ice thickness probe. Hope this helps to someone
May 21, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Mv 450 scotsman ice machine
Remove the front panel to the ice maker. There should be a control panel that will give you some more info on the fault. I am guessing that you are dealing with a short freeze cycle, thin ice, or harvest error.
May 13, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman C0330SA 1B 300 lb Cube Ice Machine Logo
1,066 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
