Hello, I have a Mitutoyo digital micrometer that I just changed the battery in. It hasn't been used in several years, I put my caliper battery in and it worked fine a few days ago. Now I put in the new battery and the readout shows 0.000000 with no change as you turn the dial and it shows a "P" flashing. Any ideas
Hit the origin button the p will go away
Posted on Aug 18, 2009
0-1 mitutoyo micrometer reads E--o5 i have replaced battery and cant make it go away?
A data sheet I got with my Digimatic 572
series scale says:
"Keep the scale unit free from water and oil.
Do not dip or sink the scale unit in liquid.
If E--05 is displayed, wipe the scale surface
with a soft cloth. Apply a slight amount of
low viscosity oil, such as CRC3-36, to the
scale surface to keep out water."
mitutoyo micrometer reads o5 Google Search
Mitutoyo Support
http://www.mitutoyo.com/
Jun 29, 2017 | MADE Computers & Internet
How do I shut it off
Digital micrometers with LCD displays usually do not have a power on.off feature. Older units have an "on" button only that is used to turn them back on after a predetermined time-out or period if inactivity to conserve battery capacity but newer Mitutoyo mics cannot be turned off.
Feb 26, 2015 | Mitutoyo 317-351 Digital...
How do I change the battery in a mitutoyo digital caliper
Find the little battery compartment on the back. Slide it open, tap lightly against your hand to drop the battery out. Insert a correctly-rated new replacement battery in the same orientation as the original battery. Slide the cover back on. They make it about as simple as possible.
Jul 24, 2014 | Mitutoyo 500 171 20 Digital Caliper
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
Oct 17, 2012 | Mitutoyo Dial Calipers
I have a mitutoyo digital caliper model 500-230. i replaced the battery but when i pressed the on/zero button the display keeps running like its counting down and will not stop. The in/mm button seems to...
Sounds like the new battery you installed is no good. Is the display also dim? When the battery is low that is one of the results on the Mitutoyo. Do you have another battery to try in it?
Jan 08, 2011 | Mitutoyo 500 506 10 Electronic Digital...
How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
0-1 OD Digital Mic Mitutoyo hard to spin
You have a nice micrometer! Your problem could be caused too many different things. I would take the lead screw spindle off first and then clean both assemblies. (You can use W-D 40) this will allow you to clean the I.D. I do not know how much you understand how a micrometer works and would caution you not to adjust any of the adjustmants on the micrometer because it could end up out of calibration. I would be happy to take a look at it and free it up and calibrate it for you! I was the Manager and working Supervisor of a precision Tool Room for over 25 years and have quite a selection of parts. I would not want any compensation for the help and I would just ask that you include a prepaid return package. I am retired now and miss the work and I am constantly cleaning all my tools and I could do it then. Here is my e-mail address jedriscoll@rcn.com
Good luck, Jack
Aug 18, 2009 | Mitutoyo 293 340: Test & Measurement...
I need to adjust a 293-761-30 mitutoyo micrometer.
there should be a small silver spanner with a couple of pins protruding to do that with comes in the box if you haven`t got it come back to me
Aug 15, 2009 | Mitutoyo 293 831 Electronic Digital...
How to reset Mitutoyo 314-351 "V" anvil micrometer. It should not read "0" when turned all the way in.
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
Jul 28, 2009 | Mitutoyo Measuring Tools & Sensors
Computers & Internet Logo
341 people viewed this question
David Payne
David Payne
