Question about Kenmore Dishwashers
WHEN i START THE DISHWASHER MOTOR IS NOT WORKING
  • Kenmore Master
  • 3,247 Answers
Usually when you start the dishwasher, you should hear the inlet water valve operate and let water in. The wash motor cuts in much later. If you do not hear the motor but everything else seems to be ok then the motor has burnt out. But if you hear nothing once you press the start button, then it is likely the cycle is not starting as the door is not locked. This could mean either the door switch is faulty or the latch is not engaging the door switch. It might help to please clarify the situation as above and also provide model number of dishwasher.
Posted on Dec 04, 2012
  • 1 more comment
  • mythily Dec 04, 2012
    you should hear the inlet water valve operate and let water in. The wash motor cuts in much later. If you do not hear the motor but everything else seems to be ok and the model number is 665 17032 400
    this is exactly what is happening initially water valve lets the war in then the motor tries to start but soon the sound dies and nothing happens
  • Sam Dec 06, 2012
    If the wash motor sound is heard but it dies, then most likely the startup capacitor (item 26) is faulty. Refer diagram on this page.http://www.searspartsdirect.com/partsdir...
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
My Frigidaire Dishwasher motor is not spinning rinse cycle
am not sure.. just try this
Check with a multi-meter for 115/220V on motor's tags.
If you don't get this voltage measurement, your problem is not with the motor.
In case you have 115/220V on motor's tags, try first to replace its brushes (2 carbon contacts that transfer the curent to the motor's armature).
try this good luck
Dec 25, 2007 | Dishwashers
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Sishwasher not used for months. Now motor only
Disassembled dishwasher. Some plastic scraps had shredded and wound itself around the pump impeller axis. It was preventing the motor from turning. Upon removal diswasher again worked fine.
Oct 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher makes a noise like it's going to start
It sounds like the pump motor has failed but the timer is working to turn on the heating element.
Recommend you replace the motor.
Apr 08, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher will not start.
You more than likely have a faulty motor on your dishwasher.  This would be the main motor that pushes the water through the spray arms inside the dishwasher.
There should be a tech sheet behind the control panel of your dishwasher or maybe behind the lower kickplate.   This will give you the readings for the motor so you can test with a volt meter.
Give this a look first.  If the motor tests good then you may be looking into replacing the timer.
Thanks, Bill
Nov 26, 2008 | Dishwashers
Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Mar 04, 2008 | Dishwashers
Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 10, 2007 | Dishwashers
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
