Question about Robin Subaru Electrical Supplies
Generator surges unless it runs at half choke
  • 4088 Answers
SOURCE: Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Posted on Jul 14, 2009
rwvanlue
  • 486 Answers
SOURCE: Yamaha ef2400is generator needs some choke to run
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Dec 04, 2009
  • 1267 Answers
SOURCE: My 4 year old Craftsman
Not that i am aware of, however, I suspect that as soon as you load it up it will die again as the load will call for greater speed, and too much fuel from the choke position will cause it to die again.
What I suspect is that your carburator is clogged up at the jets and is not metering the air fuel mxture properly. You may have to disassemble the carburator and clean it. Since the government has mandated that gasoline contain 10% alcohol, it has become a night mare for small engines that are not used very often. The alcohol is very hydroscopic (retains water) and during the off use period, the alcohol evaporates and leaves the water behind to mix with gunk and clog the needle valves.
Try removing the old gasoline. Refill the machine with fresh gasoline and add some "SeaFoam" (an additive) or any other brand additive that will help disolve the built up gunk in the carburator. Remove the air cleaner and try spraying a carburator cleaner down in the air intake while the machine is running, this way the air passages may clear while the new gasoline may dislodge the built up gunk. Note: The carb cleaner will stall the engine.
It is probably wise to run the gas tank dry before storage and only fill when the machine will be used. Stabil is an additive for storage, and it did it's job before the alcohol edict. I am not sure that Stabil will allow long time storage. (more than 3 months) SeaFoam can be purchased at WalMart, stabil is on the shelf of most small engine sales rooms such as Sears.
Posted on Jan 09, 2011
  • 3 Answers
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Posted on Jan 17, 2011
  • 185 Answers
SOURCE: I have a coleman Generator 1850. It stalls when i
Hello, I would check the carb for being dirty inside. It sounds like the needle valve is dirty, or not adjusted correctly, or there is rust in the carburator and any of these can cause the fuel not to feed into the engine properly. A good cleaning of the carb and proper setting of the needle valves should clean it up. Also check the screen in the fuel tank on the fuel valve.
Posted on Jan 22, 2011
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
My generator Jetman gg7200e idles uneven it accelerates and decelerates all the time unless i keep the choke nearly closed
That kind of surging usually happens when you are running out of gas. Is the fuel tank full and is it getting enough fuel to the carb when it needs it?
Aug 12, 2014 | Electrical Supplies
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
10HP Subaru/Robin gas on generator engine only runs smooth with choke half on, what can cause this? also the extra jet on the outside of carb what does it do?
Not sure about the "extra jet" on te side of the carb without a specific model, but running smoothly with half choke indicates that your mixture is lean. Choking it richens the mixture.
The extra jet may be your idle stop, or it could be the idle mixture adjustment.
Jun 29, 2010 | Coleman Electrical Supplies
I have a Generac XL4000. It rill start but not run right.
If the area you live in has alcohol added to their unleaded gas, then you will probably need to rekit the carbuerator. Also check the spark arrestor for plugging up. Try to find a non alcohol, off road unleaded gas for your generator.
Jan 20, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Coleman 5000 watt generator Tecumseh 10 hp engine. Surging r.p.m. Carburetor has been gone through 2 times, and still not correct. Any information will help!!!
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Will crank and run but gover arm will move and make engen run fast and slow,when a load is applied it will run ok sometimes i can put the choke on half choke then turn the choke off and it will run ok for...
It sounds like the carburetor needs to ether be cleaned or rebuilt. Try running a little bit of carburetor cleaner through it and see if that helps. If not then take it in for a tune up. Have them rebuild the carburetor while they have it and this will get you back in business. Hope this helps. Good luck.
Dec 08, 2009 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
Top Robin Subaru Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
