How to change RF output on Motorola DCT700 from Ch 4 to CH 3?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Unless it has a switch it may not be possible.
Posted on Dec 04, 2012
4 Suggested Answers
  • 864 Answers
SOURCE: I need to manually turn the TV to ch 3 and cannot because it skips it from 4 to 2.
Enter "3" or "03" on the remote and press OK/Enter.  If the channel-skip feature is set on for Channel 3 you cannot get to it using the up/down buttons.  Go to the setup menu to disable the channel-skip for Channel 3 if you want to tune it with up/down buttons.  If you have no remote you should be able to access the menu from buttons on the front of the TV. (They may be inside a door or panel.)
Posted on May 20, 2009
  • 65 Answers
SOURCE: Strange symbol come across my tv screen (example @#%chñ¿<?)
change the Eprom IC
Posted on Apr 10, 2010
alexander404
  • 276 Answers
SOURCE: I am trying to connect a DVD player to a RCA
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Posted on Aug 22, 2010
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
I need a schematic for a RF p300-1 amp. Im trying to replace 2 of the mosfet semiconductors that got fried.
There are no schematics for RF amps, normally RF uses standard IRF Mosfets. Can you decribe the area where they blew, Power Supply are usually N-Channel high current type. Outputs can be either N-Ch or P-Ch depending on the Power rail there attached to.
Dec 23, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
DO THE DCT700 CABLE BOXES HAVE AN TV TUNER BUILD INSIDE THEM?
RTFM!
  • MPEG-2 digital video processor
  • ATSC standard Dolby® Digital (AC-3) Audio Processor
  • ITU standard 64/256 QAM/FEC enhanced adaptive equalizer
  • On-board real-time RF return (256 Kbps)
  • Bitmapped graphics display (4-/8-bit)
  • 90-860 MHz Tuner
  • DES-based encryption DCII access control
  • Digital diagnostics
  • Frequency agile 2.048 Mbps out-of-band data receiver
  • Macrovision copy protection
  • IR support for remote control
  • RF remodulator output (ch. 3, 4)
  • Baseband video and audio outputs
Jul 20, 2010 | Arris DCT700 DTV Receiver
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
J5
Jan 23, 2009 | GoVideo Go Video DVD/VCR Combo
Switchable RF input
Press the channel selection switches at the same time until RF03 or RF04 display. Select the correct channel by pressing the UP ch. button.
Dec 11, 2007 | GoVideo VR4940 DVD Player/VCR
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
