Question about APC Back-UPS RS BR1500-IN (BR1500-IN) UPS System
Unit won't turn on
    Filmmaker:
    Uploaded 5 video answers.
  • 45 Answers
If the overload indicator is lit, the most likely cause is there are more devices plugged into the UPS than is can support. Try unplugging all devices but one and see if the unit functions normally.
You can then try to figure out how many is too many.
Posted on Jan 01, 2013
jitenok
  • 151 Answers
SOURCE: APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 08, 2008
JaxPlanet
  • 921 Answers
SOURCE: overload light lights and unit beeps.
It sounds like the battery is compatible with the ups.
However, APC has excellent free phone support.
I recommend that you give them a call.
Be ready to give them the model number and serial number for your UPS.
(800) 555-2725
Please vote for my solution if it helps you solve your problem.
Posted on Sep 05, 2009
loumsc
  • 114 Answers
SOURCE: Overload LED lit, constant warning tone, no load
I have seen this caused by a defective battery. Disconnect the battery and reconnect to AC and see if the overload symptom disappears.
Lou
Posted on Sep 12, 2009
  • 25 Answers
SOURCE: beeps and overload light flashes
Internal fault.
Posted on Mar 09, 2010
  • 1116 Answers
SOURCE: I have an APC-325-LM battery
Without knowing the exact sound or beep the system is making it would be hard to diagnose the problem. I have provided the APC troubleshooting page for your UPS and the various sound codes so you can further identify the problem. If you need more help, please let me know
http://nam-en.apc.com/app/answers/detail/a_id/480/kw/warning%20sound/session/L3RpbWUvMTMwNTUxMzEzMi9zaWQvU0M4SWQzdWs%3D
Posted on May 16, 2011
My unit indicates a system error due to amber LED was lit whenever I press the power button. I tried to press the remind button in the operator panel but no LED will lit to indicate what maybe the problem....
Interesting, sound like a failure of the button because most system either work with a greeg lit up led or fail with an amber or orange lit or flashing.
In this instance the amber could mean something has gone bad but the fact you can hold the button and have it boot up is strange.
Does the led turn green after holding the button for a while to let the machine boot?
regards,
mike
Oct 19, 2012 | IBM System x3500 (7977F2U) Server
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Sub-zero 430 stopped cooling.
The most likely failure (after a power outage) is your start capacitor or start relay. I would check them closely.
Jan 02, 2012 | Refrigerators
I have a Marantz AV Receiver SR 3053 with Pure Acoustics speakers purchased as one. Just today, when the unit is power on and pressed the button for power ON, there is no display and the stand-by indicator...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 26, 2011 | Marantz SC-11S1 2-Channel Amplifier
My ac unit is not working....when I turn the thermostat on, it sounds like it's trying to come on however, the fan in the unit is not blowing air. The Model #FS3BRA-024KA. The unit is 10 yrs old.
If you are talking about the indoor blower, you can possibly take the door off the air handler, make sure the door safety switch is pressed in, and try turning the blower wheel with your hand and see if it will start. If it binds up and still won't start, the motor bearings are worn and you will need the motor replaced. If it starts up, and runs for a while, you may have a bad capacitor. The capacitor looks kind of like a battery and is mounted to the side of the blower wheel housing. Be careful working with electricity, I hope this gets you started in to finding the problem. Mark
Jul 10, 2011 | Heating & Cooling
The red power light indicator flashes and the unit will not power up. I unplug the unit and try to start it up but the same thing happens. The unit will try to power up then stop and the red power light...
Despite no mention of the specific product...
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 09, 2011 | Audio Players & Recorders
Out of the blue I turn on my DAV-SC8 and after about 4 seconds the entire unit turns off ... even the red standby button goes out ... it is as though the unit dies. I switch off the wall plug and switch...
Apr 28, 2011 | Sony DAV-SC8 System
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
APC Back-UPS RS BR1500-IN (BR1500-IN) UPS System Logo
186 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
