Question about Cannon Woburn 10560G / 10562G / 10565G Gas Range
Pan holder (support ) for a sp1 - Cannon Woburn 10560G / 10562G / 10565G Gas Range
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
How to replace a oil pan gasket 2004 nissan xterra
are you referring to the lower sub pan or main oil pan? the lower sub pan on most nissan engines are fairly easy to diy. just unbolt all the fastening bolts and you would need a pry bar or screwdriver to pry off pan. remove the old liquid gasket on pan and on main pan mating surface and reapply liquid gasket. reinstall lower sub pan and install fastening bolt.
if you are referring to the engines main oil pan its a more extensive repair. you would need the correct tools and equipment such as trans jack and engine support holder.
Oct 11, 2014 | Cars & Trucks
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
How to remove transmission fluid pan.
first off drain the fluid out of the transmission pan. I always remove the return hose(which is driver side on rad base) and put into a container. Put e-brake on start vehicle and put into drive, this will drain fluid out of transmission. When fluid stops flowing, re-attach return line to rad, put transmission back into park, shut off engine. Remove drain plug from bottom of transmission pan to drain remaining fluid. You will have to disconnect the front axle drive shaft to remove transmision pan. There are 4 bolts attached to flange at front of axle. Remove these bolts and nuts only and move shaft out of the way. Mark placement of at least 1 bolt on flange. If the bolt placement is not correct you will have vibration when 4 wheel drive is engaged. (Grease the bolts when putting back together.) Remove transmision dip stick from holder. There are 2, 10 or 12 mm bolts that hold the dip stick holder in place. These are 1/2 way down the holder and are attached to engine. You can reach these from top or bottom of vehicle. Replace at least 1 bolt when you put back together. If not the holder will vibrate against engine and will be annoying.
There are 10mm bolts holding the pan in place, remove all but one. When ready ensure there is enough clearance to allow the transmission pan and holder to be removed. Remove last bolt, as the pan drops, you will have to keep the pan level. Basically hold the pan and pull it down in a way that removes the dipstick holder. Since you have the pan off replace the fluid filter and clean plate filter is attached to. Also clean off magnets in transmission pan. The magnets are what picks up any metal pieces. Leave magnets in pan. When putting pan back on replace gasket if required and tighten bolts in offsetting pattern to allow for even seal. I believe it is only 14lbs torque required for the bolts. Do not over tighten as these will strip easily.
Dec 22, 2010 | 1999 Suzuki Grand Vitara
My dough holder jumps out of the base and will not lock in. This makes the machine unusable unless you hold the inside down.
If your machine has the 2 metal clips that hold the pan down just find something that you can use to bend those clips out and away about a 1/4 inch perhaps and then they will hold your pan down and in alot better. They act to hold down your pan and sometimes get weak or overused and need to be bent back out so they do their job.
Nov 11, 2010 | Breadman TR850 Plus Bread Maker
THE CAR STARTS, THE SHIFT LEAVER MOVES TO ALL THE POSITIONS BUT THE REANSMISSION NEVER ENGAGES AND THE CAR WONT MOVE.
how easily dies the shifter move? if it feels as if there is no pressure, then possibly the cable is broken. have you had the fluid level checked? maybe there is a leak you are unaware of.
Oct 08, 2009 | 2004 Ford Freestar
When the machine is kneading now the pan has started to jump out of place
Try more water - you get a soggy load - should stick to the recipe
this sounds like plain old wear and tear to me.
Oct 19, 2007 | Breadman TR2200C Ultimate Bread Maker
Cannon Woburn 10560G / 10562G / 10565G Gas Range Logo
23 people viewed this question
Top Cannon Kitchen Ranges Experts
paulcarew
Vernon Taylor
 Mikey
Mikey
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
